Middlebusters - am I missing something?
/ Middlebusters - am I missing something? #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
Lots of talk about these, will they did a trench, etc. By the name I guess they might be called a poor mans turning plow??? (Note the ??? I'm not sure, open for discussion).
Some have seen my homemade multi tool bar thingy. Mostly I have some chisel plows and I use it for loosening up the ground and sort of raking up a virgin area I'm about to disk (garden, food plots, etc). When I made it I also made a middlebuster looking thing, but never used it. Yesterday I wanted to flip some ground so I adapted a second buster to the tool bar. I got all this old stuff from my uncles farm scrap pile. The pics are what happened.
First I could not get it to dig very deep. maybe 10 inches once you cleared away the dirt pile. A little deeper in the soft already plowed garden. QA second pass and the spoils would fall back in the hole. I fabbed up the second one to speed up my plowing process. With the holes in the tool bar I could remove one and put the other in the middle for the skipped rows.
I also ran it in some grassy areas. The MB that's on the left never clogged up. It's a little more upright, stuff would just peel off it nicely. Clogging wasn't a problem in plain dirt.
So what to yall actually use these for? Am I using it correctly? It worked ok, I ran over the area with a disk afterwards. Tough riding on the first pass, then it smooth out.
Anyway here are a bunch of pics to look at.
Rob
A few more....
in the end that grassy area looked like this...
/ Middlebusters - am I missing something? #4
Whooeee...!! Looky there --- diggin' in the dirt in Feb! I can just smell that fresh dirt all the way up here!
Looks like more fun than just about anythin' ya gotta keep yor clothes on for!?!!
I think "workin right" can be judged by your last pic --- nice, cleared, dirt. Waitin' for the planter...
Thanks for the pics and the opportunity to dream a bit.
AKfish
/ Middlebusters - am I missing something? #5
Just out of curiousity, what was limiting the depth of the trench? I was under the impression that a turning plow or a middlebuster both would dig as deep as you want them to, until something limited the depth of dig. Or to quote the guy that told me this, "a turning plow will dig to China if something doesn't stop it"
Horsepower, angle of the plow, 3pt bottoming out all seem to be things that limit the depth of the trench. I just had a middlebuster given to me, and it is going to require some work before it gets dirty.
David from jax
AKfish
Yep I did a little rowing, I still can't get this 1 row cultivator to row like I like, but it'll do I guess.
Don't tell anyone up north, I worked over 4 different areas(and we got about 3" of rain on saturday :D) , I planted 4 small blocks of corn, half row of potatoes, and 2 short rows of peas. If we don't get to bad of a freeze it may make it. I'll start planting more blocks in 2-3 more weeks. I like to get an early start. :D
David from jax
Actually I wasn't trying for depth. I'll give that a go in a couple weeks. But it seems if I made another pass, with the spoils on the sides and the height of the plow, the new spoils would just go up and over the back or fall back in the hole. Maybe a deeper hole but not a clean hole. I posted a pic of a super-sized MB I found I can't wait to try out.
Also maybe something to do with the angles (might be able to adjust this), On every row I would start with the MB and 3pt all the way down. I'd only bring it up if the tractor bogged down or started spinning.
Rob
/ Middlebusters - am I missing something? #8
Rob,
That naked dirt looks good!
It's funny that your set up with those blades are called "furrowers" out here. I've got a set ready to plow my food plot in March.
Looks like you got yours working great man.
/ Middlebusters - am I missing something? #9
Rob,
I have seen these used to dig potatoes in the garden. (tater plow)
/ Middlebusters - am I missing something? #10
RobJ -
You might find it useful to pick up a moldboard plow, it does a better job than a middlebuster. It turns the furrows over completely, burying trash and weed seeds, rather than just ripping up the ground. Nothing wrong with using what you've got though when you have a job to do.
I use a middlebuster for making potato trenches and for plowing them up in the fall. You can also make small hills, as your photos showed, and plant on the ridges. I do that with garlic.
oliver28472 said:
Rob,
Come to think of it I think I tried this on my potatoes last year. It was a mess. I was probably missing a step but basically wanted the plow to flip out the potatoes. I usually only plant 2 rows, about 60-80' each. So digging by hand isn't tough. I even plant by hand, not hard in this soft fluffy soil, push them in, dust the hole.
Nice thing about taters, nothing will bother the plant(cows). Last year I had my best garden, pulled some corn, peas. 2 weeks later cows broke in and ate everything but the taters. I shored up the fence this year and added a 5th wire.
Eastinlet said:
RobJ -
This is what I use to make the rows. I replaced the middle half plows with another small sweeper, works a lot better now. In years past I used my neighbors rower. Worked perfect but was is to big for me.
/ Middlebusters - am I missing something? #13
Robj -
Not sure why it didn't work for you, but I'll try and describe how we do it for a couple thousand feet of row.
For planting I set the middlebuster to make about a 6" deep trench into which goes the prescribed amount of fertilizer by soil test. Then drag it with a chain to put a few inches dirt on the fertilizer, without which it can burn the roots. Plant seedpieces in the furrow and cover. When plants are up about 8" I hill them, then in the fall when the vines have died back we dig them up with the middlebuster.
To dig them, set the plow so it runs just below the depth of the seedpieces, and the taters roll out of the ground. It pays to have straight rows, BTW. I like to lengthen the toplink to get the most lift possible out of the plow. Still need to rake the loose dirt with a potato hook since some potatoes are covered. We don't spear near as many tubers this way and it is a lot less work than digging with a fork. Hope this is helpful.
Thanks, I'll have to try this. What does "I hill them" mean?
Rob
/ Middlebusters - am I missing something? #15
RobJ -
That's a little different than I am doing it. The cultivator would be handy since it kills weeds in the row middles if that is a problem at planting time.
I'm using a plain old middlebuster or lister, making one row at a time.
Here's a pic of a dug row of Dark Red Norlands. As you can imagine there are twice as many covered with dirt, but lightly dragging a potato hook around uncovers them. Two people with hooks will keep four people busy lifting potatoes.
/ Middlebusters - am I missing something? #16
Hilling means mounding earth onto the plants from both sides creating a ridge.
The potato plant can make more tubers this way, and it shelters the tubers from disease and high temperatures. You really want to do it if you want more potatoes, though a lot of guys just plant them flat.
Man that is real cool. I don't get as many that big. A lot of what we call (we our family that is) are popcorn potatos. About as big as a half dollar or smaller. Still just as good.
Thanks for the pics!
Rob
/ Middlebusters - am I missing something? #18
I like the little ones myself, especially in pot roasts and soups.
There are a few tricks to growing good potatoes. I've never been to Texas nor do I understand your climate, so keep in mind what I offer is general advice.
The biggest factors are fertilizer and water. Potatoes are a very heavy feeder, far more than corn and you have to have the nutrients (preferably based on soil test). I'm applying 10-20-20 at the rate of 150 pounds of actual N per acre.
Potatoes need about an inch of water a week from bloom until after the potatoes have bulked. They can be planted very early to take advantage of seasonal rainfall patterns. It sure would be nice to irrigate as needed...
As I mentioned, hilling helps a lot with yield and also keeps the tubers from greening in the sun.
It pays to buy certified seed of a cultivar that grows well in your area and fits the season length. There's a lot of difference in performance between varieties. Late season potatoes outyield early ones of course. Space the seedpieces based on desired tuber size, i.e. if yours are running small you could try spacing the seed wider, even up to 14" or so to reduce inter-plant competition.
/ Middlebusters - am I missing something? #19
East,
Last potatoes I have harvested (helped), my grandfather and "Nell" rolled out.
Help me out, when you say hilling do you cover soil up on the plant and how much, 1/3rd 1/2 or more of the height?
Neil
/ Middlebusters - am I missing something? #20
neil -
Couple of things to consider when hilling.
First is when to hill, and that is best done at 8-12" in plant height. The buried stem will sprout tubers, and all tubers form between the buried seedpiece and the surface of the ground. If you let the plants get away from you like I did last year, it is a royal pain to hill in a tangle of vines.
Height of the hill is basically as broad and high as you can make it. On 36" row centers you will be grabbing dirt almost to the center of the row middle. With 10" plants you want them covered right to the tips if you can do it. Don't worry, they'll grow back out from under the dirt.
Hilling twice say 2 weeks apart works well if you have the time or spit for it. If you do this, you can hill first when they are say 6" and then hill again at 12" or so.
If you look at the linked photo I posted above you can see hills down the rows of dead vines. It was a poor job on my part and of course the hills settle over the summer so they aren't as dramatic as they are fresh.
The trick is to mechanize the hilling using disks or cultivators rather than a hoe. the big farmers up this way use Lilliston rolling cultivators which throw the dirt from row centers onto the hill and can do many rows at once. The old horsedrawn hillers used cultivator teeth to loosen ground for two opposing angled disks which scooped dirt to the hill. I'm working toward mechanizing, that hoeing just isn't as fun as it used to be.
John Deere 7230 (A62180)
John Deere 7230...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
iDrive TDS-2010H...
Massey Ferguson 573 (A64126)
Massey Ferguson...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
