Middlebuster\Subsoiler Build
   / Middlebuster\Subsoiler Build #1
XxLT250RxX
NW Alabama
I want to build a combination middlebuster and subsoiler. I have looked at many on this forum and found lots of good info. I have ordered the furrower from Agri Supply (see link). What I need to know and have not been able to find is the the size of the material to make the shank from. My tractor is a 60hp 2 wheel drive Ford. Does anybody know what size material the ones sold by Tractor Supply are made from? The nearest TS is a good ways from me. I may have to make a road-trip.
Agri Supply - Farm Supplies, Tools, Lawn Mower Blades, Cast Iron Cookware
   / Middlebuster\Subsoiler Build #2
I think the TSC model uses 3/4" x 4", but I'm not completely sure. I built my own too and used 1" x 5" as mine extended deeper than the TSC model. I've attached a couple of pictures of mine as it neared the end of construction. Note I included an option for depth adjustment beyond what the 3-pt would give. Also made it convertable for going either forward or reverse. In the pics, it's turned to the reverse position.
   / Middlebuster\Subsoiler Build #3
Sub soiled is1 1/2 solid, plow is hollow .two 1/2 inch bolts sandwich them between the angle iron,this frame style also gives you extra height for limited car 1 tractors
CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
CATERPILLAR D8T...
2012 KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
2012 KOBELCO...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
