Mowing middle blade not cutting
/ middle blade not cutting #1
peppertruck
Cherry Valley, NY
Kabota BX2230
I own a Kabota BX2230 with a 60 inch midmount mowing deck. The middle blade keeps stopping when cutting; also makes loude noise. Can anyone help?
/ middle blade not cutting #2
Loose blade or grease on belt.
/ middle blade not cutting #3
Maybe a spindle freezing up. Some things you just have to check out yourself. Remove the deck, loosen the belt and check for binding, noise, looseness of parts.
/ middle blade not cutting #4
... 1st, Have you been greasing the spindle zerks? -- but that would stop all blades if center siezed.
2nd, loose center blade or worn washers on blade bolt.
/ middle blade not cutting #5
Time to pull it off and have a good look at the bottom of the mower. You might find the stuff holding the blade in place needs tightening or replacement.
/ middle blade not cutting #6
I had this happen on my BX. Loose blade was my culprit.
/ middle blade not cutting #7
Stretched or wrong size belt?
/ middle blade not cutting #8
The center spindle runs directly from the gearbox on a BX mower deck and there is only the one huge sepentine belt that drives the left and right spindles. If the center blade is slipping, it can only be a loose blade. That center blade can be very hard to remove or tighten.
I just had the same thing happen on the center spindle on my BX deck. My attempt to simply tighten the bolt snapped the head of the bolt off. The repair involved drilling out the old bolt, re-threading the hole and a new factory bolt with an additional washer. Tedious work.
See if the bolt is simply loose on yours but don't repeat my mistake and over-tighten it. If the bolt is tight and the blade still slips, remove the bolt and add a washer.
/ middle blade not cutting #9
I once had a compactor that worked for 20 sec and then stop working......checking the wobblebox it was free ......finnily found the problem.......freeplay on the bearings was not enough .
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
Alligator Statue (A64557)
Alligator Statue...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
