mid pto hydraulics
/ mid pto hydraulics #1
vidio1
Bronze Member
Madisonville
Kubota B7610
At some point I'd like to add a backhoe to my tractor ( how I found this site) either built or bought. My tractor only has 4.4 gpm, so probably not enough to run a backhoe, external pump will most likely be a necessity. I've seen rear pto pumps and they would probably be fine, but I was thinking about a mid mount pump. I've got a mid pto just sitting there not doing anything and not planning on doing anything with it, so.... I've skimmed over a dozen or so threads about the subject and didn't see much in the way of anything being completed. Has anyone run one long term? Pros and Cons? What would you do differently?
/ mid pto hydraulics #2
I'm not opposed to a rear pto pump, but I am a 3pt hitch mount. I just thought a mid pto pump would be a novel approach as it's not being used. I envision a permanent self contained mount for the pump and a 4 point mount for the hoe, quick release style with 2 quick couplers for the hoses. 2 pins and 2 hoses and it's on or off.
/ mid pto hydraulics #4
Did you check out the link?
/ mid pto hydraulics #5
Below is exactly what my brother purchased last spring for his J.D. 30 something , newer version of the 790 . It is around a a 25 + or - pto tractor . We used it this past spring in putting a complete underground sprinkler system in at Our Mom's house , over 900' of pipe . It is pretty cool in that you don't have to be running at max rp to dig , were as my TC 30 with Factory 757 BH functions best above 1500 rpm's .
6'Dig Tractor Backhoe w Tank Pump Filter PTO Powered Cat I 25HP BHM6 | eBay
His did not cost that much as it was on sale . Also purchased a 5' tiller , that is pretty impressive and even Her neighbors have said the Garden soil looks better than it ever has .
Fred H.
@ Looking4new I did check your link, but they are all 3pt mounted. I know there are a bunch of them sold, but I just don't see how more housings aren't broken. I'd prefer a subframe type, I know Woods makes a subframe for my tractor, just don't know the model #.
/ mid pto hydraulics #7
I have a sub mount on my TC 30 and Brothers is a 3 point . I was skeptical of 3 points , But in operating his last summer , One would have to abuse it beyond what I would even do with a sub frame to break housing's or anything else . There was a issue with TC 30's breaking housing's on a few tractors here on the board , BUT there was never a " This Caused " it answers . To many varibles even with a sub frame . For instance , Using the stabilizers or BH bucket to " Lift " the BH to tighten the top link tighter . BAD idea !! Causes to much torque between BH and rear of tractor .
If one use's either BH mount to the limit of the Tractor and BH spec's , I really doubt there will ever be a problem .
Fred H.
Yeah, I've skimmed over a few of those threads and others like them, that's part of my concern. I'm no Engineer but in my mind the attachment points on a tractor are designed for pulling or pushing in one direction and not for the twisting/tugging and shock loads from all directions. If I break something on a subframe I can most likely repair it myself, If I break a chunk off the rear housing it's a costly trip to my local dealer. Usually I baby my stuff, but my stepkids and neighbor could break an anvil in a sandbox with a marshmellow hammer so it's a real concern.
I've looked through that thread too. I'd have to agree with most of the statements there.
So back to one of my original questions, has anyone successfully used a hydraulic pump run off a mid pto? Assuming front and rear pto's are 21hp with 540 rpm rear and 1000 rpm mid which has the most potential for a higher flow @ around 2500 psi ? Are the front and mid pto rated for the same hp?
/ mid pto hydraulics #12
I have never ran anything off my mid mount pto . I would Think though that it would have to be secured similar to how a fluid type pump for sprayers is secured to the rear pto ????????????? Maybe actually fab a plate that the pump would mount to , which then could be mounted to the tractor frame some how . The coupler could be a Lovejoy coupler or something similar that could handle the h.p. . Would be similar to how a log splitter works .
Again though , pure speculation . That is how I thought of utilizing my mid pto , just never got around to that project yet .
Fred H.
Massey Ferguson 4710 (A60462)
Massey Ferguson...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Woods DS8.50 (A60462)
