Mice repellant
/ Mice repellant #1
Dennisfly
Lake Anna, Virginia and Alleghany County, VA
John Deere 4410
When I lifted the hood to check the oil, I saw the southend of a northbound mouse scamper out of the engine. I have heard a story of a mouse chewing through wire insulation and causing a fire. Any ideas on how to repel them. I park in a field. I was thinking maybe mothballs!
/ Mice repellant #2
</font><font color="blue" class="small">( I was thinking maybe mothballs! )</font>
Dennis, I don't know; maybe mothballs will work for mice, but my brother had a problem with squirrels getting inside the rear end of his motorhome where they chewed up the wiring to his backup camera twice. Someone told him mothballs would keep them out, so he put a lot of mothballs in there. The squirrels carried all the mothballs out and dropped them in a pile on the ground under the back end of the motorhome. /forums/images/graemlins/laugh.gif
/ Mice repellant #3
Howdy.
I have a few ideas.
Once in a previous "life" I worked for a pest control company. We used dozens and dozens of these "Ketch all mousetraps". They work really well.
Ketch all mouse traps
The neat thing is that they catch multiple amounts of mice 24 hours a day. They are tin metal traps that you just wind up and put them on the ground around your tractor. My guess, is that 6-10 of them strategically places around your tractor would work fine.
Cost is about $15 each. But you'll own them forever, if you dont run over them!
If you're "cheap" then here's another idea. /forums/images/graemlins/wink.gif
Just take several 1 x 4" pine boards, maybe 1 to 3 ft long and tack nail on about a dozen or more old fashioned Victor snapper mouse traps. Put peanut butter on each trigger and set them. Each morning, just pick up the boards from around your tractor and go to work. Remember those mice dont "fly" up on your tractor. They climb from the ground up the wheels or front end loader, so place the traps near the climbing points.
Reset the little snappers in the evening when you park the tractor. Also, the snapping action of a trap can trigger the other snappers, so maybe you only put one or two on each board, depending on the sensitivity of the snapper. The idea, is just to isolate the trap from the grass so you can find it and pick it up to reset.
It'll work. You'll be amazed at how many you will catch, but eventually, you'll clean out the field populations and get very few. That is what you want!
Last note, if other big vermin are getting in there and snapping the traps, then make some kind of cover so the cats or whoever cant disturb them. /forums/images/graemlins/mad.gif
Cardboard boxes work good.
good luck! /forums/images/graemlins/smile.gif and please post back messages if it works or doesnt work for you!
dwight
/ Mice repellant #4
If you have AC power around the electronic rodent repellers work pretty nice. I put them in my shop buildings and house and have not seen any evidence of mice since. Probably will work with squirells too, since they are rodents.
/ Mice repellant #5
Since mine is parked out "in the woods" under a "Costco Carport" I've had mouse problems too. Tried both mothballs and mouse poison. They didn't mind the mothballs enough to keep them from eating all of the poison! I still have at least one that likes to nest under the fuel tank on the clutch side, but last time I started up, the fan evidently got him! For now I'm going with leaving a box of poison on top of the engine.
/ Mice repellant #6
Mothballs might discourage mice early in the season when they are just looking for good nesting spots, but may not do much once they have established a nest site.
Enclosing several mothballs in a number of nylon sachets made from old stockings and tying them to wires can prevent them from being removed from the locations. You will have to replace them every year or so.
Mothballs are usually not enough to seriously discourage rats and squirrels however, and they can chew some serious wire!
Rip
/ Mice repellant #7
Why not just stick a cat under the hood?
I'd suspect you'd want to remove him just before starting up the tractor. But I also suspect that any mouse silly enough to crawl up there when a cat is present will find a very disgruntled cat who is just itching to do take out his aggression on something small and furry.
/ Mice repellant #8
I like BOB's Idea!
one cat can make a lot of mice unhappy. at least mine does, she gets them all the time, and lately she usually comes form the far back barn cause all the close up ones are already passed through the cat at least once. I have traps set and I still catch moles every now and again but so does she, cause she leaves them lay after catching em, myst taste bad or something! lol /forums/images/graemlins/blush.gif
Mark M
/ Mice repellant #9
I used a 5 gallon pail with some peanut butter smeared on the inside lower edge. Then I put about 4" of water in the bottom of the pail. Made a ramp to the top of the pail for the mice to climb up on. The mice would dive into the pail trying to get to the peanut butter and would drown in the water. I have mixed emotions about this method, but at the time, it was effective. Now I use bate boxes and poison only when the mice are a problem in the house. I let nature deal with the outside mice. The local snake population seem to deal with them well, so it is only in the winter that they come around and the poison gets them in the garage before they come inside.
/ Mice repellant #10
</font><font color="blue" class="small">( They didn't mind the mothballs enough to keep them from eating all of the poison! I still have at least one that likes to nest under the fuel tank on the clutch side, but last time I started up, the fan evidently got him! For now I'm going with leaving a box of poison on top of the engine. )</font>
I always worry about poisoning mice outside. It poisons the hawks and the owls right along with them and maybe some cats or dogs. And whatever you do, don't poison mice in the house, because they will go in the walls and die later, then stink up the place and generate a whole herd of flies.
Cliff
/ Mice repellant #11
I have one of those, found it in a wharehouse the was going to be torn down. Seems to work most of the time but I've had several mice cut in half jamming it as well.
I have a kitty that keeps most of them away. He eats the stupid ones.
/ Mice repellant
Boy! What a bunch of different and great ideas. The neighbor's cat does prowl on occasion, but apparently not often enough. I don't want to poison any hawks or owls. The windup mousetrap has merit, as does the bucket of water with peanut butter. When my house is built and I get electricity, I like the idea of the electronic repeller. I'm going to have to mull this over. I guess the mothballs aren't going to get the job done. Thanks for the suggestions!
/ Mice repellant #13
The electric repeller didn't repel what ever beast moved undre our place during the winter. The holes looked rat sized, so I tried rat traps. The monster under the house carried them all off, glue or Victor. I had a serious talk with the wolf pack, but they are just shinin' me on. The only squirrels I ever saw inside were reds and we have so many grays around that there couldn't be a red. It ain't a weasel either they stink! /forums/images/graemlins/tongue.gif
/ Mice repellant #14
Seriously, you could get/have a couple of "barn yard cats".
The only thing is, sometimes the Owls hunt the cat, but that is really a rarity. Put a small cat house for shelter and your mice problem is solved, guaranteed. G
/ Mice repellant #15
Here's a stupid idea. Don't park in a field. I rent space from a neighbor near my property for $25 month, well worth it. He doesn't use the garage space and my machine is safe and clean. Cheaper than building a structure.
/ Mice repellant #16
kmornin a bull named no1
/ Mice repellant #17
Slamfire,
The electronic repellers will not work very well thru walls and floors. Were the electronic repellers under the floor ?
/ Mice repellant #18
I posted this picture of this device that sits on my tractor in another thread, but I will post it here too. It does a hell of a job on mice.
/ Mice repellant #19
Ugh a cat! Had a stray sleeping on my tractor seat and throwing up in the seat, furballs, dead bird parts, etc...... no more kitty /forums/images/graemlins/smile.gif
2019 GREAT DANE CS1-1314-21053 53X102 DRY VAN TRAILER (A59912)
2019 GREAT DANE...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
