MF 65 rebuildable?
/ MF 65 rebuildable? #1
Bpawb
I am in need of a medium-size utility tractor, found a Massey Ferguson 65 , gas engine Continental 176, 1958 or 59 model the tractor runs great, has like 4200 hours showing ..... If I buy this tractor, is it likely to say in the future I can find all necessary parts to do all mechanical repairs to keep this 65 running from now on, or are their mechanical parts that are unavailable? This is a good running tractor for 3300, I need it for tilling, and is about all I can afford... is it a decent choice? Or should I save my money until I can afford something larger and more modern?
/ MF 65 rebuildable? #2
My father has had a 65 for several years now, and repairs and maintenance have been as expected, with no major breakdowns. The biggest aggravation on these models is replacing a radiator belt, since you have to remove so much stuff. Anyway, they are quite reliable, and the continental is a good engine. We have found that any MF dealer can get the parts you may require; keeping in mind we haven't had any major problems.
As far as the cost.. I would save a couple thousand more dollars and buy a newer 165 or even a 135, and get a perkins diesel. Just a thought...
SM
/ MF 65 rebuildable? #3
The 65 and the 165 are very reliable tractors and the parts for these models are readily available. About the only difference between these two models is the sheet metal. I find however that a vast majority of these tractors are diesels, therefore parts for the gas engine may be harder to get. As Southernman stated you may be better off to get a diesel.
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
John Deere MX5 (A64126)
John Deere MX5...
2010 GREAT DANE SUP-1114-11053 53X102 REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
John Deere 6110M (A64126)
John Deere 6110M...
