MF 65 Hyd
   / MF 65 Hyd #1
sitn
Osyka, MS.
MF 65, Farmall Cub, JD 450B
Greetings, As a new member of the thread, I outside of Osyka, MS. and have three tractors. MF 65, Farmall Cub and a JD 450B. I have a question for the MF65. Just recently installed a remote valve selector on top of the transmission case and ran two hoses to the dual spool valve to operate a dual tandem disk. Problem is this. No lifting of the disk. The PTO does work because I use my bush hog. The three point hitch works also. The valve body has six ports, two for fluid in and out. Two upper and two lower ports. Exactly which ports do I use to go to the hyd cylinder on the disk?
sitn
   / MF 65 Hyd
Thanks. This new for me to navigate through. Have to get used to the way things are done. Harder than some other sites I belong to.
   / MF 65 Hyd
Nice looking rig you have there. I finally got my remote cylinder to work, except one of the tie rod bolts on the cylinder broke. Replaced two and then the o'ring seals blew out on the clevis end. What a day.
   / MF 65 Hyd #7
Welcome to TractorByNet!
I moved your thread to the Massey Ferguson Owning & Operating forum. :)
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2004 GREAT DANE 53FT DRY VAN TRAILER (A52141)
2004 GREAT DANE...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
