MF 1739E Electrical Question
/ MF 1739E Electrical Question #1
ellisco1
Palestine
MF 1739E
Hi all,
I'm new here and I didn't find this when I searched so here it is.
Just bought a 1739E (haven't actually received it yet) I use and electric spray rig so I want to add a 12 volt switch leg on the rear so I can turn the sprayer on/off from the driver position. I notice that fuse 4 on the block is labeled "outlet". I didn't see any aux outlets on the tractor. Does anyone know what that circuit is for? To put another way, if anyone has purchased the service manual can you let me know if that circuit is up for grabs?
/ MF 1739E Electrical Question #2
There is a connector that comes out of the wiring harness at the base of the ROPS on the left side. I think the tractor needs to be running in order for it to be active, I could not get it active the one time I checked it out while the tractor was parked in the shop. There is not a switch on it so I assume you will need to provide your own switch and connector with ground for your spray rig.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2014 Hyundai HL760-9A Articulated Wheel Loader (A61572)
2014 Hyundai...
2012 JAYCO PINNACLE ALL-SEASONS 5TH WHEEL CAMPER (A64280)
2012 JAYCO...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
