MF 1533 Starving for fuel
/ MF 1533 Starving for fuel #1
Maverick2022
mf 1533
When running the tractor, the fuel bowl empties and the tractor stops running. With fuel pump off the bowl fills up. Also, if I clamp the line that returns to the tank from the near the injectors the bowl stays full, and the tractor runs. What is wrong? Cleaned tank, changed filter, and blew out lines. Please Help!!!!!!!!!
Dale D.
/ MF 1533 Starving for fuel #2
Rubber hoses falling apart inside?
/ MF 1533 Starving for fuel #3
Does it have a hose from the top of the filter base going up to a tee in the return line from injectors to tank? if so, pinch that line off and try things again. See what difference that makes.
yes that is what I have done to make it work. When doing that, the bowl stays full and the tractor runs.
/ MF 1533 Starving for fuel #5
So do what I do in that situation. Snip the hose a few inches from each end. Put a screw, small bolt, or a piece of rod into each of the short ends to plug them off. Go back to work.
But what causes this?
/ MF 1533 Starving for fuel #8
I'm not really sure, but I suspect it's a combination of things related to fuel traveling from the tank to the filter base. I never see it in newer tractors, only once they get some age on them. Is it build up inside the fittings, lines, ETC, something actually in the tank affecting fuel flow? I don't know if it's always the same cause, just that it's usually the same result. Fuel doesn't flow fast enough from the tank and the filter base can actually draw air in from the return line above through the (supposed) vent hose which affects the supply out of the filter to the pump.
will this hurt the tractor?
Thanks so much will run it today with bulldog clip on it.
/ MF 1533 Starving for fuel #12
Reading your posts maybe my problem and your is related. I have a MF1835 that at 1/2 tank of fuel will stop when climbing and incline where the engine is higher than the fuel tank. 1st time service dealer suggested new filter. only 135 +tax no change but in looking how the fuel line is strung out from tank to filter then goes to radiator to cool continuing to fuel the emission system . uses diesel for cleaning exhuast system.
I have found the inlet to the filter fitting collects trash or what ever it is and blocks the filter line .I just make sure the tank is full before using anywhere other than level ground.
No conplaints just wish a drawimg of system and where found was included in purchase.
Also the battery is cheaper designed than a Wal Mart lawn battery. looks good but no voltage.
ken
/ MF 1533 Starving for fuel #13
ken
If your tractor has a fuel cooler it's probably a common rail fuel system which would be completely different from what's being discussed here.
/ MF 1533 Starving for fuel #14
Reading the supplied book on this tractor. only explaination is uses diesel for emmission control ,and tracing the lines from filter to front of Radiatior is another cooler. asking the deailer they said is a fuel cooler. light on dash shows when it is cleaning emmissions from exhaust.
My comment was on the post of fuel shortage and my suggestion was may be simular to mine. Don't know the fancied termination. only what i have found to cause fuel to be restricted to the fuel pump.
ken
/ MF 1533 Starving for fuel #15
Have you been able to eliminate all contaminates "trash" from your fuel system?
Once contaminants get into your tank it can be quite the job of removing them without completely removing the tank and flushing it upside down.
/ MF 1533 Starving for fuel #16
I had a similar problem with my 1540(95% same), after getting a delivery of bad fuel. Tried many unsuccessful fixes for months.
Getting the tank out of this model is a bi%ch.
Finally broke down and bought some fuel tank “cleaner” product, and within 2 tanks, it was completely back to normal. Haven’t had the problem again.
Not an endorsement for this product by any stretch, im usually pretty anti-snake oil additives. Just an fyi screenshot of what product I happened to pick up at the store.
I still have the remaining product in my garage
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
Freighliner Tender Truck (A61306)
Freighliner Tender...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
