MF 1533 hydraulic change
/ MF 1533 hydraulic change #1
mf94
fallston
I changed the fluid in my tractor today but after putting fluid in I'm guessing I have air in the system because I have no power-steering and the bucket and rear won't lift up. Do these have a bleeder somewhere on them or should I keep working the bucket?
/ MF 1533 hydraulic change #2
Did you get your answer on this? I just changed my fluid and filter today on my 1533 and encountered the same problem. Not sure exactly what to do. Thanks
/ MF 1533 hydraulic change #3
There is a bleeder on the hydraulic pump. Do you have an owners manual? HST or Powershuttle?
/ MF 1533 hydraulic change #4
On top of the hydraulic pumps located on the side of the engine is a round manifold tha tooks like a hockey puck. Loosen the screwand start the engine - tighten the screw after you quit seeing air bubbles. Don't loosen it too much or you will be getting an oil bath.
2025 Wolverine PFA-11-3300G Hydraulic Forks Skid Steer Attachment (A59228)
2025 Wolverine...
2019 BOBCAT T450 SKID STEER (A60429)
2019 BOBCAT T450...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
