MF 135 AG3
/ MF 135 AG3 #1
11143wmj
Irmo, SC
MF 135
I have a 1974 MF 135 Perkins AG3 How do I set the timing with distributor. I also have a box blade attached to the three point hitch. The box blade is not low enough. Can I change out the length of the lift arms? Use longer ones.
/ MF 135 AG3 #2
:welcome:
/ MF 135 AG3 #3
:welcome: to the forum.
There is a timing window on the left side of the block. The timing marks on the flywheel, you may need to clean them up to see them. Timing needs to be set 12*BTDC. Max advance is 24-28*BTDC.
I do not recommend modifying your lift arms to work with your box blade. They will not work right for other attachments then and it will cut down on your lifting capacity by extending them. You would also need a new toplink. I think the best thing would be to raise the attachment points on the box blade.
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
John Deere 3025E (A64126)
John Deere 3025E...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
Kubota M6950 (A64127)
