mf 130 hydroulic pump cross over part
/ mf 130 hydroulic pump cross over part #1
pedwards4570
1972 mf 130
I have a mf 130 my 3 point hitch is stuck up I'm pretty sure the control valves are stuck any help with a alternate pump number and or locating rebuild parts would be appreciated
thank you
/ mf 130 hydroulic pump cross over part #3
Why do you think the pump is bad if the 3 point is fully raised?
/ mf 130 hydroulic pump cross over part #4
Check the response control.At max it can prevent the 3ph from lowering when empty. Resonse control is behind your right heel.
ive checked the draft control and rate of speed control and response control i can relive pressure at auxiliary port above pto and it goes down will go up as soon as engine is started was thinking stuck control valves my nephew moved it from under cover and let it sit out side hydraulics were contaminated with water so I drained and refilled still the same
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A60430)
2007 FORD F750 XLT...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
2020 DRAGON ESP...
2022 John Deere 5055E (A60462)
2022 John Deere...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
