mf 130 hydroulic pump cross over part
/ mf 130 hydroulic pump cross over part #1
pedwards4570
1972 mf 130
I have a mf 130 my 3 point hitch is stuck up I'm pretty sure the control valves are stuck any help with a alternate pump number and or locating rebuild parts would be appreciated
thank you
/ mf 130 hydroulic pump cross over part #3
Why do you think the pump is bad if the 3 point is fully raised?
/ mf 130 hydroulic pump cross over part #4
Check the response control.At max it can prevent the 3ph from lowering when empty. Resonse control is behind your right heel.
ive checked the draft control and rate of speed control and response control i can relive pressure at auxiliary port above pto and it goes down will go up as soon as engine is started was thinking stuck control valves my nephew moved it from under cover and let it sit out side hydraulics were contaminated with water so I drained and refilled still the same
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
CAT Chassis Only (A59076)
CAT Chassis Only...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
