Mechanically-challenged tractor owner
/ Mechanically-challenged tractor owner #1
swswarthout1
Mineral, VA
Johm Deere 3720
My wife bought me the tractor many years ago while I was getting adjusted by a chiropractor for a strained back. It has made my life easier and cost the chiropractor much in lost fees. On occasions it has given me indications that I have not been able to interpret. I cannot find what I have done with the DVD that came in lieu of a manual, which is a challenge. I have joined this group in hopes that your wide, collective experience will be of help. Right now, when I turn the switch to start the glow plugs, all of the instrument lights flash together repeatedly. Any ideas?
/ Mechanically-challenged tractor owner #2
Welcome! What kind of tractor is it?
/ Mechanically-challenged tractor owner #4
Welcome to TBN...enjoy.
Try Search column always good advice given.
/ Mechanically-challenged tractor owner #6
HST right? Check and see if your go pedal has returned to null position.
/ Mechanically-challenged tractor owner #8
and enjoy the forum!
Many thanks for your suggestions. I pulled the battery and had it tested, it was good. I cleaned the terminals and the lugs, reinstalled the battery and had momentary success, and then flashy,flashy. I put an ohmmeter across the + post and the lug - nada. Loosened the lug and twisted it until it seated hard, retightened the lug, and Success! I think the + lug is a little oversized and it is hard to tighten it with the nut so close to the lug. Probably time for a couple of washers.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A65563)
2011 Ford F-350...
2023 Bobcat L28 (A64126)
2023 Bobcat L28...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
