Max amp for wire
   / Max amp for wire #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
Can any of you master electricians tell me how many amps 6 AWG TW 600v UC Pump cable SX-PA can carry. I'm having a 20kw gen set installed and wanted to use this wire since I have 50 feet of it. The electrician tells me I can't, because it's 50 amp wire and he's installing a 100 amp service and has to use a different wire. Is this a true statement?:confused:
   / Max amp for wire #2
Your electrician is telling you the truth. I think, not sure, that you would have to use a 2awg wire or even a 1 awg wire to handle the 100 amp service.
This might help?
Wire-Gauge Ampacity - Transwiki
   / Max amp for wire #3
If you have to buy wire for that 100A service, look into aluminum. It requires a heavier guage, but is substantially cheaper than copper.
I think it is 2-2-4 URD for 100amp service and 4/0-4/0-2/0 for 200 amp
The 100amp stuff is pretty cheap. ~$1.40-$1.50/ft
   / Max amp for wire #4
#6 copper good for 50 amps. hes correct. 20 kw = 83.3 amps. rate wire for 90 amps . 2/2/2/4 SER aluminum is good for use on this. thats what i use. Its about $2.5/foot as i recall. They also make it in a metal clad wire called MC thats great if the wire is going to be left exposed or can get damaged. Aboput $3.50 ish per foot.
   / Max amp for wire
Thanks guys, I learned something new today:thumbsup:
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
Quick Attach Pallet Forks (A47384)
Quick Attach...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
