Master B/R makeover
/ Master B/R makeover
A slightly better view of odd floorplan
/ Master B/R makeover #22
</font><font color="blue" class="small">( Finally get floor DONE )</font>
Great feeling isn't it? Especially after you've done such a great job.
I recently asked TBN if someone had interest in making a column base and I ultimately found a very nice older fellow locally that made them. This is what he made
I went up/down 2 flights of stairs to “micromeasure’ this round part to try to get the column to fit as snugly as possible
*what I mean is, each circle was carried up/down 2 flights of stairs about 10 times EACH /forums/images/graemlins/crazy.gif as I shaved the bare minimum off so that it would fit right the FIRST time, rather than to cut it too much & ruin the piece.. it was the up/down/up/down incessently, that wore me out.
ty... posting this story is almost as much work!! we're ALMOST done!!
Fitting pretty nicely, raised the “rings” so I could screw it down to the base
all snugged up on a trial fit
First column installed
Second column after painting
Column and French doors
The front room after floor, daybed & some decorations
Finished view. NOW we (she) gets to start decorating as all the heavy stuff is done.
/ Master B/R makeover #33
looks really great.. lot's of work to complete that project..
Thank you... and yes, it really was a lot of work. Then again, bro in law built shell and other than drywall installation & kitchen cabinets, we've done 100% of the rest, including sealing (tar) the entire backside of house that was under grade. Flooring, trim, fixtures, fans, pond, rock retaining walls, waterfall, flagstone patios/sidewalks, doors, insulation, phone wiring & now columns & windows /forums/images/graemlins/grin.gif
So, we've done a lot of work overall.
I personally sanded the entire exterior with a 5" sander prior to staining it. Wore my little fingers out /forums/images/graemlins/tongue.gif
/ Master B/R makeover #35
we've been toying with an idea to swap the walk in closet and M/B room. This, would put the bath on two outside corners and the closet with only one out side wall. Would take a lot in configuring the plumbing and electrical, the rest wouldn't bother me too much..
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
207277 (A52708)
207277 (A52708)
2010 JCB 3CX 4x4 Loader Backhoe (A60352)
2010 JCB 3CX 4x4...
2019 Dodge Grand Caravan Van, VIN # 2C4RDGBG8KR553728 (A61165)
2019 Dodge Grand...
(2) Edgers (A62177)
(2) Edgers (A62177)
Better Built 100 Gallon Fuel Cell with Pump (A61166)
Better Built 100...
