Master B/R makeover
/ Master B/R makeover
A slightly better view of odd floorplan
/ Master B/R makeover #22
</font><font color="blue" class="small">( Finally get floor DONE )</font>
Great feeling isn't it? Especially after you've done such a great job.
I recently asked TBN if someone had interest in making a column base and I ultimately found a very nice older fellow locally that made them. This is what he made
I went up/down 2 flights of stairs to “micromeasure’ this round part to try to get the column to fit as snugly as possible
*what I mean is, each circle was carried up/down 2 flights of stairs about 10 times EACH /forums/images/graemlins/crazy.gif as I shaved the bare minimum off so that it would fit right the FIRST time, rather than to cut it too much & ruin the piece.. it was the up/down/up/down incessently, that wore me out.
ty... posting this story is almost as much work!! we're ALMOST done!!
Fitting pretty nicely, raised the “rings” so I could screw it down to the base
all snugged up on a trial fit
First column installed
Second column after painting
Column and French doors
The front room after floor, daybed & some decorations
Finished view. NOW we (she) gets to start decorating as all the heavy stuff is done.
/ Master B/R makeover #33
looks really great.. lot's of work to complete that project..
Thank you... and yes, it really was a lot of work. Then again, bro in law built shell and other than drywall installation & kitchen cabinets, we've done 100% of the rest, including sealing (tar) the entire backside of house that was under grade. Flooring, trim, fixtures, fans, pond, rock retaining walls, waterfall, flagstone patios/sidewalks, doors, insulation, phone wiring & now columns & windows /forums/images/graemlins/grin.gif
So, we've done a lot of work overall.
I personally sanded the entire exterior with a 5" sander prior to staining it. Wore my little fingers out /forums/images/graemlins/tongue.gif
/ Master B/R makeover #35
we've been toying with an idea to swap the walk in closet and M/B room. This, would put the bath on two outside corners and the closet with only one out side wall. Would take a lot in configuring the plumbing and electrical, the rest wouldn't bother me too much..
New/Unused Landhonor Quick Attach Hydraulic Pallet Forks (A61166)
New/Unused...
2006 Hypac C530AH Pneumatic Wheel Compactor (A61567)
2006 Hypac C530AH...
2025 SDLGC100 6 Passenger Electric Cart (A60352)
2025 SDLGC100 6...
(2) 320/85R24 TIRES W/8LUG RIMS (A62130)
(2) 320/85R24...
2006 Freightliner Auger Truck (A63118)
2006 Freightliner...
2025 LandHonor HPF-11-3000G 48in Hydraulic Adjustable Forks and Frame Skid Steer Attachment (A60352)
2025 LandHonor...
