Master B/R makeover
/ Master B/R makeover
A slightly better view of odd floorplan
/ Master B/R makeover #22
</font><font color="blue" class="small">( Finally get floor DONE )</font>
Great feeling isn't it? Especially after you've done such a great job.
I recently asked TBN if someone had interest in making a column base and I ultimately found a very nice older fellow locally that made them. This is what he made
I went up/down 2 flights of stairs to “micromeasure’ this round part to try to get the column to fit as snugly as possible
*what I mean is, each circle was carried up/down 2 flights of stairs about 10 times EACH /forums/images/graemlins/crazy.gif as I shaved the bare minimum off so that it would fit right the FIRST time, rather than to cut it too much & ruin the piece.. it was the up/down/up/down incessently, that wore me out.
ty... posting this story is almost as much work!! we're ALMOST done!!
Fitting pretty nicely, raised the “rings” so I could screw it down to the base
all snugged up on a trial fit
First column installed
Second column after painting
Column and French doors
The front room after floor, daybed & some decorations
Finished view. NOW we (she) gets to start decorating as all the heavy stuff is done.
/ Master B/R makeover #33
looks really great.. lot's of work to complete that project..
Thank you... and yes, it really was a lot of work. Then again, bro in law built shell and other than drywall installation & kitchen cabinets, we've done 100% of the rest, including sealing (tar) the entire backside of house that was under grade. Flooring, trim, fixtures, fans, pond, rock retaining walls, waterfall, flagstone patios/sidewalks, doors, insulation, phone wiring & now columns & windows /forums/images/graemlins/grin.gif
So, we've done a lot of work overall.
I personally sanded the entire exterior with a 5" sander prior to staining it. Wore my little fingers out /forums/images/graemlins/tongue.gif
/ Master B/R makeover #35
we've been toying with an idea to swap the walk in closet and M/B room. This, would put the bath on two outside corners and the closet with only one out side wall. Would take a lot in configuring the plumbing and electrical, the rest wouldn't bother me too much..
2010 Nissan Rogue SUV (A61569)
2010 Nissan Rogue...
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
Decorative Horse Light Post (A61569)
Decorative Horse...
2017 Nissan Sentra Sedan (A61569)
2017 Nissan Sentra...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
