massey ferguson 285
/ massey ferguson 285 #1
cowski
Platinum Member
Alabama
cx70,5510,4630,5005, 108s
i need a cheap old tractor for some rough bush hogging jobs and to set out hay in out of the way places. i ran across a mf 285.i would steer away from the larger masseys ,but the smaller ones have been ok.is the 285 reliable or does the design have any major faults?
surely someone has been around a 285
/ massey ferguson 285 #3
We have had one for many years. Strong tractors. Weakest thing on a 285 is blowing a head gasket. We use ours for a loader tractor nowadays and it gets started and stopped maybe a hundred times a day. The tractor did not give the gasket blowing problem when we were farming with it? Ken Sweet
/ massey ferguson 285 #4
The head gasket was the symptom rather than the disease. Problem was solved with retro-fit head stud kit and a redesigned head gasket. (Studs rather than bolts) And those issues were brought out when many original 285/1085 owners juiced up the injector pump to get closer to 100 hp from a tractor that just wasn't intended to be turned up that far.
Most 285's and 1085's were re-fit years ago, or else they're sitting in fence rows now.
I'm kicking myself almost daily for letting a VERY nice 285 w/cab get away a year ago. It had less than 1000hrs, all mowing horse pastures (w 8' mower) It looked BETTER than a new one, and was reasonably priced.
thanks for answering, recon how much a retro-fit kit costs.sweettractors does yours have a retro-fit on it.one benefit to the older masseys is they have less stuff to knock off when bush hogging brush.my newer tractors keep getting stuff knocked off.
/ massey ferguson 285 #6
Did Massey correct the head stud problem in later model 285's or was the problem present throughout production? If this problem was corrected by mf what year did they do this?
/ massey ferguson 285 #7
I've had my 285 for several years and no problems yet. That thing is a mule. I cut and bale hay with mine and run a 15' batwing with it. Great tractor. :thumbsup:
/ massey ferguson 285 #8
I never had a problem with my 285 when farming with it. However, as a loader tractor, it gets a head gasket every year. That is with the factory upgrades. Ken Sweet
/ massey ferguson 285 #9
Guess I have been lucky with mine. Going on 4 years with a loader and so far so good, knock on wood.
/ massey ferguson 285 #10
What a load of rubbish ..certain models and trannies maybe but no different to any other brand .
/ massey ferguson 285 #11
Mine gets started probably 50 times a day and unloading 36 crated disc mowers from a 40 ft container at full throttle for 2 -3 hours don't help the situation any. I think I am going to cut back the max engine rpm this spring. That should help some. Ken Sweet
/ massey ferguson 285 #12
I agree 100%. I would put a MF up against any brand out there.:thumbsup:
/ massey ferguson 285 #13
Yea thats a lot of use. Hope cutting back on the rpms helps out. I work mine everyday but not like your doing.
/ massey ferguson 285 #14
I think that re-checking the head torque after 50 & 100 hrs when a head gasket was replaced cut down big time on repeat failures. Some went as far as checking it every 100 hrs untill the proper spec was obtained.
/ massey ferguson 285 #15
Have a MF S90 puller toy with 410 combine block, 318 5 inch crank, original head studs and Lawson 01420 hex high nuts, longer than stock nuts to help hold gasket better. Like the idea of nut and block threads both about same, original short nuts don't torque as well.
/ massey ferguson 285 #16
The 285 is the pit bull of tractors. I have 1 in service on my farm in Penna.
Its powered with a Perkins 318cid 4cyl The head gasket problem is B/S
For the life of me I can understand way you would need to replace a head gasket each yr??? That mechanic that works for you SUCKS. There is no data or any info from Perkins about head gasket trouble., Unless it was run HOT.
The Perkins 318 was used in marine apps as well because of how well made the engine is.
Also was used in military gen sets, water pumps, Tug boats and so on.
I have 4500+hrs on my 285 Never Ever any problems with head gasket.
Take care of it and it will run for ever. Do not start it cold. Use the block warmer in winter. NO STARTER FLUID EVER!!!
And don't let that guys mechanic who does a head gasket ea yr mess with it. No disrespect,But he sucks.
/ massey ferguson 285 #17
Listen man, you can have your opinion, but dont tell someone no disrespect & then tell them them they suck. Thats an oxy moron, and just plain rude. Everything thats man made can and will fail within certain parameters. Maybe you didn't read the whole post. He said he never had any trouble while farming, just since he started using it at his shop. THINK BEFORE TALKING
/ massey ferguson 285 #18
i have a 285 mf has a lot of blow by and skips and puffs a lot of blue smoke could this be a head gasket?
/ massey ferguson 285 #19
Usually you should smell the antifreeze in the exhaust smoke from a blown head gasket. What is the tractor history of oil consumption or oil in the water or water in the oil? Ken Sweet
/ massey ferguson 285 #20
I agree.
We had 2 mf 698 turbo's that had 318's in them pushing out almost 100hp pto , One did 10'000 hrs opened once and the other blue smoked it's way to 14'000 hrs having never had the head off . Ether is fine if used properly these two had plenty of it :)
