massey ferguson 285
   / massey ferguson 285 #1
cowski
Platinum Member
Alabama
cx70,5510,4630,5005, 108s
i need a cheap old tractor for some rough bush hogging jobs and to set out hay in out of the way places. i ran across a mf 285.i would steer away from the larger masseys ,but the smaller ones have been ok.is the 285 reliable or does the design have any major faults?
surely someone has been around a 285
   / massey ferguson 285 #3
We have had one for many years. Strong tractors. Weakest thing on a 285 is blowing a head gasket. We use ours for a loader tractor nowadays and it gets started and stopped maybe a hundred times a day. The tractor did not give the gasket blowing problem when we were farming with it? Ken Sweet
   / massey ferguson 285 #4
The head gasket was the symptom rather than the disease. Problem was solved with retro-fit head stud kit and a redesigned head gasket. (Studs rather than bolts) And those issues were brought out when many original 285/1085 owners juiced up the injector pump to get closer to 100 hp from a tractor that just wasn't intended to be turned up that far.
Most 285's and 1085's were re-fit years ago, or else they're sitting in fence rows now.
I'm kicking myself almost daily for letting a VERY nice 285 w/cab get away a year ago. It had less than 1000hrs, all mowing horse pastures (w 8' mower) It looked BETTER than a new one, and was reasonably priced.
thanks for answering, recon how much a retro-fit kit costs.sweettractors does yours have a retro-fit on it.one benefit to the older masseys is they have less stuff to knock off when bush hogging brush.my newer tractors keep getting stuff knocked off.
   / massey ferguson 285 #6
Did Massey correct the head stud problem in later model 285's or was the problem present throughout production? If this problem was corrected by mf what year did they do this?
   / massey ferguson 285 #7
I've had my 285 for several years and no problems yet. That thing is a mule. I cut and bale hay with mine and run a 15' batwing with it. Great tractor. :thumbsup:
   / massey ferguson 285 #8
I never had a problem with my 285 when farming with it. However, as a loader tractor, it gets a head gasket every year. That is with the factory upgrades. Ken Sweet
   / massey ferguson 285 #9
Guess I have been lucky with mine. Going on 4 years with a loader and so far so good, knock on wood.
   / massey ferguson 285 #10
What a load of rubbish ..certain models and trannies maybe but no different to any other brand .
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Unused Delta Crash...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
