Massey 1433V
/ Massey 1433V #1
Ironheadted
Massey Ferguson 1433V
I am having a problem with my Massey, I parked it the other day, and today I fired it up and went to put it in forward and it cut off. Started it up again and went for reverse, same thing, just cut off...any ideas ?
/ Massey 1433V #2
If it's a gear tractor, you have the range and gear selector mounted on the linkage shaft under the fender, it is prob. rusted or built up dirt.
Try this first put it in gear, then put the range selector in gear, but watch the shifters and see if the other shifter moves. if it does spray the shaft with PB blaster and work the shifters a few times to get them moving, usually this works. also under the fender there is a safty switch with 2 fingers with a tab from the linkage between the fingers, if it is off, just a little it will just shut itself down. you can re-ajust the safty switch so the safty work properly. it works the same way the safty switch works under the seat. when you stand up from the seat, it will shut itself down. thats where your problem is.
I had to do the very same thing on my old 1528.
Also you can see the safty I am talking about, just look though the shifter slot, and you will see the 2 fingered safty switch, by just looking down the shifter linkage.
Hope this helps
david
2022 Case CX145D SR Hydraulic Excavator (A61572)
2022 Case CX145D...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
