Massey 1433V
/ Massey 1433V #1
Ironheadted
Massey Ferguson 1433V
I am having a problem with my Massey, I parked it the other day, and today I fired it up and went to put it in forward and it cut off. Started it up again and went for reverse, same thing, just cut off...any ideas ?
/ Massey 1433V #2
If it's a gear tractor, you have the range and gear selector mounted on the linkage shaft under the fender, it is prob. rusted or built up dirt.
Try this first put it in gear, then put the range selector in gear, but watch the shifters and see if the other shifter moves. if it does spray the shaft with PB blaster and work the shifters a few times to get them moving, usually this works. also under the fender there is a safty switch with 2 fingers with a tab from the linkage between the fingers, if it is off, just a little it will just shut itself down. you can re-ajust the safty switch so the safty work properly. it works the same way the safty switch works under the seat. when you stand up from the seat, it will shut itself down. thats where your problem is.
I had to do the very same thing on my old 1528.
Also you can see the safty I am talking about, just look though the shifter slot, and you will see the 2 fingered safty switch, by just looking down the shifter linkage.
Hope this helps
david
Champion Vibratory Roller (A60462)
Champion Vibratory...
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2018 Trail King Lowboy (A63689)
2018 Trail King...
