Market for PT custom Attachment???
/ Market for PT custom Attachment??? #21
Here's another one that is more of a rock rake. Ignore the Raptor Dino-Teeth...
/ Market for PT custom Attachment??? #22
I would add these items to my wanted list:
*Log Splitter Attachment
*Chipper/Shredder Attachment
*Hi Volume Leaf blower with 180 degree adjustable directional chute
/ Market for PT custom Attachment??? #23
I would like to see any plans or entertain any thoughts on a hydraulic log splitter attachment that is both vertical and horizontal with an additional quickplate that would allow you to split logs into 1/2 or 1/3 or 1/4 etc. Maybe it could also have a hydraulic assisting arm to lift up larger logs. Sort of like a log prossesor. I think this would be awesome for both home owners with woods, people interested in making money for firewood etc. Any pictures, ideas, plans or prototypes would be great /forums/images/graemlins/laugh.gif
/ Market for PT custom Attachment??? #24
Have you checked out my log splitter. With it you don't have to get off the tractor to split and move the wood.
/ Market for PT custom Attachment??? #25
Yes - in Queensbury, NY about 50 miles north of Albany.
Steve
/ Market for PT custom Attachment??? #26
As long as we are dreaming, how about a leaf shredding vacuum. Probably have to be something along the lines of a pull-behind cart.
Honestly, this is one application that the PT does not seem very well suited for though. The front attach and articulating design would make it very hard to figure out a way to blow the leaves back to a pull-behind cart, and anything that you rigged up to hold the leaves in front would either be too small to be useful or restrict vision too badly. But hey, I know how much some of you guys love a challenge!
/ Market for PT custom Attachment??? #28
How do we feel about putting together some kind of list of attachment type and the number of people that would be seriously interested in them. I am not sure how we would do this but I would imagine that we should begin a new thread in order to make it easier to navigate.
After we establish the attachments with the greatest "want/need" value we can then methodically go through each one and evaluate the following-
1 - Will the attachment as requested operate in a safe and manageable manner as expected in concert with the PT units?
2 - Can it be made per the requested requirements within the required price range?
3 - Economy of scale - how many we would manufacture on the first run / which would have quite a bit of bearing on the price.
We can create the designs in 3d solids and then post the finished design either here or within one of our websites.
Please advise any comments on how/where to begin the evaluation of the different attachments in a semi-organized manner.
Once we get one attachement designed and some units sold we can move on to the next etc.....
I look forward to your comments.
Best Regards,
Steve
/ Market for PT custom Attachment??? #29
Jim,
Here is the Steiner Chipper-Shredder on another articulated tractor. It is driven off the front PTO. This is intended for stationary use only and not suitable for vacuuming leaves. The pulverized material is blown through the black pipe and can load a pickup bed, wagon or trailer bed, or just dropped onto the ground.
See photos of my vacuum system in the following posts. It seems to me this could easily be connected to a Power-Trac. It just requires a boot connector to the exhaust chute of the mower deck and a couple of support arms for the long hose. My hose is 11 feet long.
JackIL
/ Market for PT custom Attachment??? #30
Photos of my lawn vac on an articulated tractor.
/ Market for PT custom Attachment??? #31
Another view.
/ Market for PT custom Attachment??? #32
Another view of the vac system.
/ Market for PT custom Attachment??? #33
Final View of system
/ Market for PT custom Attachment??? #34
Stray,
I was commenting on your log splitter. Yes I definitely have seen it and the questions were directed towards you and your design. I think it's great. Please email me @ [email protected] if you want to offer any private offers or information.
/ Market for PT custom Attachment??? #35
As I looked at log splitters on the internet, mine is not much different than those built for a bobcat. Although I could build them for a cheaper price than they wanted I would still have to have about the same for it as the ones built with a motor, pump and reservoir. I really believe that if I was going to start from scratch and build another I would get one made for a 3 pt hitch and adapt. Just get the one with a full beam or one that would be most suited to adapt. You would need to buy some hoses and fittings but you would have the valve, cylinder, wedges, slides and all that.
My splitter hooks up to the PTO for fast operation. 10 second cycle time at full throttle. I don’t run it that fast when I am splitting wood though. I estimate that with the pressure that my valve is set on it will do about 20 ton. I used a 4” cylinder. If one wanted more tonnage just go to a 5” (cycle time will slow some though
2 grand would buy my splitter but I would just have to make another. I will be glad to entertain any questions or help you with any info I can. [email protected]
