Marker light bolts
/ Marker light bolts #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I need to change this marker light on the horse trailer and I can't find anything to lose these bolts. I have a couple screw driver sets with every bit under the sun and I tried hex wrenches both metric and SAE. Any thoughts on what fits these?
Never mind. I just found the bulbs to fit this so I don't need to remove it.
/ Marker light bolts #3
looks like a torx bit
/ Marker light bolts #4
If I remember right, these are Philips. Trailer manufacturers use these for assembly because the drivers are easy to center in them. Try a Philips #2. It's either Philips or square bits.
/ Marker light bolts #5
They are square drive (Robertson). They look like Torex, but are 8 sided. 2 squares 90 degrees off so the square drive fits in 2 different positions.
Never seen square drive with the holes 90 degrees off. That is the one driver I did not try.
/ Marker light bolts #7
Like Fallon says, use a square bit, a #2 if I remember correctly. I had to remove some screws for something on my enclosed trailer and this worked like a charm.
/ Marker light bolts #8
I ran into them on my Haulmark trailer replacing a side panel. They are called doublesquare and you can get 8 pt bits for them.
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
Skid Steer Flail Mower (A65640)
Skid Steer Flail...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
Troy Built Riding Lawnmower (A65579)
Troy Built Riding...
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
