Marker light bolts
/ Marker light bolts #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I need to change this marker light on the horse trailer and I can't find anything to lose these bolts. I have a couple screw driver sets with every bit under the sun and I tried hex wrenches both metric and SAE. Any thoughts on what fits these?
Never mind. I just found the bulbs to fit this so I don't need to remove it.
/ Marker light bolts #3
looks like a torx bit
/ Marker light bolts #4
If I remember right, these are Philips. Trailer manufacturers use these for assembly because the drivers are easy to center in them. Try a Philips #2. It's either Philips or square bits.
/ Marker light bolts #5
They are square drive (Robertson). They look like Torex, but are 8 sided. 2 squares 90 degrees off so the square drive fits in 2 different positions.
Never seen square drive with the holes 90 degrees off. That is the one driver I did not try.
/ Marker light bolts #7
Like Fallon says, use a square bit, a #2 if I remember correctly. I had to remove some screws for something on my enclosed trailer and this worked like a charm.
/ Marker light bolts #8
I ran into them on my Haulmark trailer replacing a side panel. They are called doublesquare and you can get 8 pt bits for them.
2014 CATERPILLAR 924K WHEEL LOADER (A65053)
2014 CATERPILLAR...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
Power command Transfer Switch (A62679)
Power command...
