Manual vs Hydro Transmissions
Status
Not open for further replies.
/ Manual vs Hydro Transmissions #81
i started with an old international gear tractor then went to kubota glide shift then to two different kubota hst's now have an m9000 gear tractor.what i liked about the hst was that i could set the throttle to mantain 540 pto speed and be able to adjust ground speed or change directions without adjusting the throttle. i could also find the right speed with it. some of my land is a little rough and on the old international it always seemed that one gear was 2 slow and the next one 2 fast. hasn't been a problem on my m9000 i think the larger framed tractors just ride better.
/ Manual vs Hydro Transmissions #82
( My brakes are fine... perhaps you are only thinking of a certain size tractor.. and not taking into account larger tractors... )
Kinda of curious what is a small tractor and what is a large tractor and why stopping should be different between the sizes.
Big Tractor/Small Tractor
/ Manual vs Hydro Transmissions #83
Soundguy said:
I'm not fond of locking up tires, breaking traction and sliding.. chews up the grass something awfull.. plus if on a hard surface.. you now have less control when sliding.
Dumping the throttle pulls you down fast, and the wheels are still turning to help prevent breaking traction. If I need extra stopping power, right as the engine pulls it down, I clutch then break at the point twher ethe forward speed is about to match dumped engine speed.
It makes a diffference when you have 10-12 thousand pounds moving.. I deffinately don't want to slide and break traction!!!
Soundguy
Chris, I don't lock my brakes up but I can do it with some effort. In fact, on a hydrostatic type transmission, you very rarely ever use the brakes except maybe as a parking brake. With 4WD you also get the benefit of front wheel braking action (when in 4WD) that is especially handy on down grades. I do agree that you get superb control using engine braking be it manual or hydrostatic, both work very effectively and my prefferred way to slow down regardless of transmission. With some manufactuers you can select just how quickly you want a hydrostatic transmission to slow you down. Of course with a geared or hydrostatic, the gear or range you are has direct corelation on just how much braking you will get. The higher the gear range, the less braking you get.
/ Manual vs Hydro Transmissions #84
I always thought that a "big" tractor was one with over 100 hp. A "small" tractor with a belly mower can be visually confused with a lawn mower. No right or wrong, just what one person uses to distinguish big from small.
Either way, the brakes should stop them. The only difference is the consequence if you fail to stop.
/ Manual vs Hydro Transmissions #85
Agreed.
Soundguy
/ Manual vs Hydro Transmissions #86
The big / small issue is kinda subjective.. however I tend to ground scut and cut into small.. and ut/ag in the big area. of course .. there will be some that set on the line.. etc.
Stoping vs size? Well.. with any of my tractors that are 40hp and down.. If I did stomp the brakes and stop them immediately.. it wouldn't be too bad.. If I stomp my brakes on my ford 5000 or my NH 7610s.. the tires do lock up.. and then leave a brown skid mark of a couple feet where they skin the grass off.
Just being able to lock tires means nothing. if you have a heavy tractor.. you have alot of stored momentum and energy. it's safer and easier to bleed it off with engine braking than stomped brakes. At one intersection i cross where it goes from gravel to asphalt to gravel.. i used to use braked on my 7610s.. till I slid out into the intersection one time.. With engine braking.. I've never done that. The bigger the tractor.. the bigger the laod it can pull.. thus the more you have to be carefull about stopping. I imagine my batwing mower on the back of my 7610s makes for quite a bit of stored energy to stop. If I'm on grass.. NO way am I stomping on brakes to stop.. I'd rather take a few feet and dump the throttle, then use the brakes at a managable speed.. or to park. Same with my 5000 and the 3pt mower. Between wet tires and front pillow weights.. it's over 9k#... lord knows what the 7610s is with wet tires, a front populated suitcase weight plate, and the 15' mower..
I'd hate to think what that would do to my pasture to rip to a halt with her...
Soundguy
/ Manual vs Hydro Transmissions #87
Hello Scott,
I understand and do the no brakes thing all the time. What I don't understand is the seemingly large numbers of compact tractors that have virtually no brakes.
/ Manual vs Hydro Transmissions #88
Well, here we come to problems in defining tractors. For some the 100HP would be consider a small chores tractor. For others a 40HP would be considered a big tractor. It's all in the perspective.
I actually consider my Kubota 16HP tractor a "Toy Tractor" but in my situation it works quite well.
If you need to stop you need to stop regardless of size. Run into a cow with a larger tractor and the cow may die. Run into a cow with my tractor and the operator may die! This is kinda important to me!:D
/ Manual vs Hydro Transmissions #89
Well for goodness sakes, get some smaller farm animals to use for substitute brakes! Maybe some sheep, goats or Shetland ponies... Cows are just to big when you're on a 16 hp tractor!
jb
/ Manual vs Hydro Transmissions #91
If speed is importanty in initiating a stop then you can't beat my Kubota HST. Most folks don't drive much of the time with a hand on the throttle or a foot on the brake. With my HST as soon as you let up on the HST pedal, where your foot is much of the time, the tractor slows very quickly. Much of the time it will be stopped or nearly so before you can get your foot on the brake. This effects a stop faster than taking your hand off of the joystick or steering wheel and reducing throttle or whatever your procedure is before putting a foot on the brake.
Now is this a big deal? NO! Not usually, but if it were to matter and you were trained to reach for the throttle first you wouldn't stop as fast. People react in an emergency the way they trained in normal ops. (A fact of life that can be confirmed with any military commander.)
Do folks usually let up on the HST "all at once?" No, because it stops way faster than is comfortable for routine ops. You can always let your foot up at a rate that reduces speed comfortably, just like using a brake to make a smooth stop. While letting up on the pedal you can reach up and reduce the throttle if you are stopping or need an RPM reduction.
I intend no put down for any other type of tranny, there are good reasons for all types. My intention is to point out some differences that may not be common knowledge to folks who have not operated an HST very much.
Not to make fun of any individual but sometimes watching a newby operating a geared tractor is entertaining. A newby may take some seat time to get comfortable with a hand throttle and sometimes things get out of control. With an HST if you just let up on the HST, a very natural action for an automobile driver because of the similarity to an accelerator pedal, the tractor rapidly slows or stops, RIGHT NOW.
Some of this is of little or not import to the seasoned hands here but it can make the difference between early success and a frightening introduction and possible disaster to a first timer. The HST IS NOT training wheels, it is a serious tool with many applications for which it is superior but just happens to be the easiest to learn. I hold no illusions about HST being the best choice for all tasks as it clearly isn't. Pulling an implement like a plow, disk, etc. for hours and hours, round and round with little manuvering is not the sort of task that would recommend an HST.
Lots of manuvering with a mower, box blade, or FEL shows the HST to be superior with the shuttle shifts and automatic clutch machines a pretty closse second.
I have a friend with a terrific tractor but it was designed for row cropping (geared 2 wheel drive) and he is a cattleman. He has a nice FEL but the front end of his two wheel drive won't let him work the FEL anywhere near capacity and it is a real PITA to manuver in even moderately confined spaces (especially using the FEL.) The only thing I have seen it excell at is disking fire breaks prior to a controlled burn and hauling a large tank trailer with engine driven pump for fire control/suppression. It would do OK brush hogging but he doesn't do much of that. An example of a great used tractor bargain at a good price but it is like buying a hammer at a super low price when the job is driving and removing screws.
My claim is NOT that HST is the best at everything. My claim is that the HST is easier to learn and use and is a superior choice for many tasks. If you just need to pull hard and drive in big circles HST is not first choice. In many instances the difference between HST and the close competition of shuttle shift and auto-clutch gets to be a fine line easily crossed to save a few bucks.
I have never heard anyone complain that their tractor was too powerful or too easy to use. Too big, yup... too hard to manuver, yup...too lots of things but never too powerful, too comfortable, or too easy to use.
I can rub my tummy and pat my head at the same time or vice versa or walk and chew bubble gum (or blow bubbles) at the same time but I don't think you require more coordination to use HST efficiently, I suspect it requires less. You can use an HST just fine without having to be good at multi-tasking.
Pat
/ Manual vs Hydro Transmissions #92
Golly Pat, are you saying that with an HST, when you remove your foot from the pedal the tractor is stopped before you can apply the brakes?? :D
/ Manual vs Hydro Transmissions #93
Pertty dern nare dunn stoped is right, bout as quik as runnin inter yer lardger ferm anmals.
/ Manual vs Hydro Transmissions #94
Wow.. i can't imagine having to mow for hours on end holding my foot down on a pedal. I know your answer is that many hydro have a crusise control, and you then just have to turn cruise off.. Well.. in the time you take to turn cruise off.. i can dump a hand throttle... Seems to me that we are both accomplishing the same thing... 1 movement to stop the tractor. Either lifting a foot, or turning a crusise off.. or moving a hand throttle...
Seems to be even money to me.. ( you are going to be fast and efficient at whatever you are used to / whatever equipment you are familiar with.. )
When I first got my 5spd 'stacked' fords.. i couldn't shift them worth a darn.. I missed the 4spds... Now I work the 5spds just fine.. in fact better.. the r/3 is across from each other on top level, and acts like a real good shuttle.
Soundguy
Pat
/ Manual vs Hydro Transmissions #95
SoundGuy, Try as I might I just can't undedrstand why you make a statement about holding your foot in a single position for hours. I have never done or thought I would need to do that. Even if you did, the ergonomic design of the Kubota HST pedal would make it pretty easy but it sure isn't required.
Cruise automatically turns off if you tap the brake or move the HST pedal. Cruise really does work neat. If for some reason you didn't want to "disturb" the cruise setting and only needed to slow down but not completely stop, you could ****** the throttle and the clutch is available if you want to completely stop without changing the cruise setting. Normally I only use the clutch for starting (lock out switch) and for engaging and disengaging the PTO.
The only time I ever held my foot on the pedal for very long in one position was all the way forward which is not particularly tiring as you can hold it with a toe, heel, left or right edge or whatever, not a cramping sort of thing. No more tiring than just having your foot resting on the floor.
Of course, with experience a good operator such as yourself and many others here learn to optimize their performance within their tractor's capability. Irrespective of what equipment you have, as you indicate the operator is an important part of the mix. Not everyone is cut out to operate equipment and there are no current designs on the market that can make everyone a good operator. I suggest the HST comes closest.
Pat
/ Manual vs Hydro Transmissions #96
Pat
Pat, no amount of explanation is going to work, GIVE UP!:eek:
I do agree with you on the cruise control on the Kubota L30 series. I have yet to see a simpler, easier, better designed cruise control on any tractor.
/ Manual vs Hydro Transmissions #97
I don't give up easily but if the communication has failed this time I guess it is a case of don't confuse anyone with facts when their mind is made up. A grade school teacher I had used to say, "A person convinced against their will is of the same opiniokn still."
There is at least one flaw in my cruise, It is not well protected and when I got really wild in heavy brush I damaged it. Been there done that and had the under tractor mechanism replaced since it was such a nice feature. L-4610HSTC
Pat
/ Manual vs Hydro Transmissions #98
Pat
I managed to break my speed sensor which is on the opposite side of the cruise on my L3830 HST. I imagine something got under there and ripped into it. As with any of this stuff, even our JD 410D backhoe which has a very sturdy under, over and all around protection we still manage to get a stick right through the front grille and through the radiator. The difference is the cost of the part and the labor bill.
/ Manual vs Hydro Transmissions #99
RaT, I have been there and done that to the Kubota too. Managed to get a limber branch to wind around and get through the radiator without making a hole in anything else. Not a high probability event but possible. I had a branch slip through a itsy bitsy path and hit the electrical connections on the starter. I didn't know until I shut down and tried to restart, way out from the shop of course.
Got the price of a new starter and a comment from my Kubota mech which was to get the current one rebuilt by a shop he mentioned. When I pulled the starter and opened it up to look (always curious) I saw a bare wire that got bent when the stick hit and was shorted out to case. Bent it away and reinstalled... works perfectly ever since. It looked like a one in a milliion shot to get anything up there to hit it but I did.
If only I had an old used off brand geared row crop 2 wheel drive tractor with steel tires and no cab I wouldn't have had either of these problems. especially if it were an air cooled diesel with the very desireable hand rank start.
Pat
/ Manual vs Hydro Transmissions #100
Pat
Once again it is pointed out that our old outdated geared 2wd tractors are virtually useless. I 'm glad I wasn't aware of that when I was stacking and feeding 400 to 600 1200lb rolls each year. I was so deprived. It did do pretty good at harrowing fire breaks, though.
Status
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
Trimble 2050 Display Screen (A64119)
Trimble 2050...
