Manual says not to use CJ-4 oil
   / Manual says not to use CJ-4 oil #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
The Owners manual for a Kubota RTV-x900 (diesel) says:
"The CJ-4 engine oil is intended for DPF (Diesel Particulate Filter) type engines, and cannot be used on this vehicle."
I've been using Rotella T4 for all my diesels which says meets CK-4, CJ-4, CJ-4plus, CI-4, CH-4. So does this mean I need to use a different oil for the RTV that does not specify CJ-4? Or, does Kubota mean only those oils that meet only CJ-4 are not to be used?
(Dealer is closed at the moment so I won't get to ask him until next week.)
   / Manual says not to use CJ-4 oil #2
What spec does your manual call for?
   / Manual says not to use CJ-4 oil #3
It says to use cf or higher in the manual. I use amsoil signature max duty synthetic 15w-40.
   / Manual says not to use CJ-4 oil #5
Please continue to use the T4 that you use in your other diesels in your climate and not start another oil thread!
Good Luck!
I concur!
The manual says:
For Ultra Low Sulfur Fuel [<0.0015% (15 ppm)]
Use CF, CF-4, CG-4, CH-4 or CI-4 Oil class of engines except External EGR
Oil class of engines with External EGR use CF or CI-4
(Class CF-4, CG-4 and CH-4 engine oils cannot be used on EGR type engines
   / Manual says not to use CJ-4 oil #9
   / Manual says not to use CJ-4 oil #10
Unless there is a typo or mis print looks like the CI-4 meets your standards. I'd run that and not look back. If the oil meets the standard you are looking for it doesn't matter what other standards it may or may not meet.
   / Manual says not to use CJ-4 oil #11
My manual for an M series has the same wording.
I buy Kubota branded oil from Kubota dealer that sold the tractor new, rating is CK-4 and also has CJ-4 CI-4 etc etc etc on the label.
   / Manual says not to use CJ-4 oil #12
Some early CJ-4 oils were not backwards compatible. I remember that was an issue with New Holland Ambra 15w-40 when their CJ-4 was introduced. What we have here I believe is another case of oil technology outrunning published info in operators manuals. Clearly Kubota 15w-40 is now rated to replace and supersede prior standards as are countless others.
You are buying oil in 2021 and reading a manual that could have been written in 2012 or 2013. The CJ-4 standard dates back to 2006.
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
yellow ball Trailer (A56859)
yellow ball...
