making mp3 files
/ making mp3 files #21
When I run the sytem information tool on my Media edition it shows up as Pro. I have not found any feature of Pro that was not in the Media edition.
There may be some. it is different from the home edition that I have on a different machine.
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name NEW
System Manufacturer Gateway
System Model 2900877
System Type X86-based PC
Processor x86 Family 15 Model 4 Stepping 4 GenuineIntel ~2799 Mhz
BIOS Version/Date Intel Corp. NT94510J.15A.0052.2005.0915.1910, 9/15/2005
/ making mp3 files
That's similar to what I had seen .. etc. Media center edition is closer to 'pro' than to home edition..
Soundguy
/ making mp3 files #23
Soundguy said:
Wow... that's amazingly rude!
I agree.
Here's some help.
Plus! Audio Converter LE is part of the free Windows Media Bonus Pack. Click Here
Here's the description.....
Plus! MP3 Audio Converter LE
Sample a feature of Plus! for Windows XP and double the amount of music you can store on your computer by converting your MP3 files quickly and easily to Windows Media Audio (WMA). Get Microsoft Plus! to unlock all the great features and take Windows XP to the next level.
Here's a link to the Plus! site Click Here it costs $14.99.
I agree with MossRoad about Audacity. I tried Media Jukebox and, at the time I tried it, was nagware.
/ making mp3 files #25
Soundguy said:
Wow... that's amazingly rude! You imply that my answer is wrong, then when i ask wht you believe the correct answer is.. you make a condescending comment???? Soundguy
Wow ... sorry. Thought you wanted to get a job done, not dwell on why you can't do a job with what tools you've got.
My inference was that your emphasis was on an operating system, not the app itself ... or, more to the point, you got replies indicating what it takes to get the job done, but you have to stop on the point that you can't do what Jimbrown can do with the tools he has.
So, as I rarely submit comments that I don't subscibe to myself, here is a case in point: (caution, tech stuff to follow).
A minor project this weekend was to record a block of content from a particular internet radio station that I really like. Listening via the net is fine in the house as well as on my estate using my high-power Ramsey FM transmitter but, is impossible in the car (with my capability) or at any other location without broadband.
So, I figure I'll use an old "stream-ripper" that I employed some years ago. Crap, can't find it, and don't have time to find another one that's free and actually works how I want it to.
No prob, I'll use the TV card in my PC hardwired into my AV system ... well, no go ... the s/w for it flakes out on me now.
Ok, well, I can always go "old school" and record a 6 hour block on my VCR then digitize it at my leisure. That's what I wound up having to do. More work, but will get the job done and it's mostly PC time, not "my" time.
Step 1: Record net stream onto VCR. Well, no prob except that girlfriend brought up an old Tivo to add to my existing 6 devices connected by a huge mass of cables to my PC. Had to use a "y" RCA connector on both channels to get the stream plumbed into the front of one of my VCRs. Done. Works good.
I set the VCR to SLP (6 hr) mode. The video portion is crap, IMO, but audio is quite acceptable.
Step 2: I've only been at this MP3 thing for 8 years (that I can remember) and don't think Audacity was available then so I use CoolEdit Pro for all my audio digitizing projects. (Dozens of LP's, 45's, cassetts, ... FM broadcasts.)
CoolEdit is bulletproof, if you know what you're doing. I had to set the input levels to ~-9db on the "monitor VU meter" setting and make sure I had enough HD space to commence. FYI, raw WAV files take ~10MB/min. A 6 hour block ~3.5GB. I have an NTSF partition for video stuff any way incase it runs over 4GB.
I'm digitizing at the default 44.1Khz sample rate, 16 bit stereo ... just because it all takes the same amout of time. After contacting the radio station owner, the stream is only at 64kbps ... but what do I care.
Step 3: Man, that's a big file. Wish I had a modern PC. Anyway, because I just started recording "whereever" and stopped it when it ran out of tape, I trimmed the ends to the nearest beginning/end of a tune in CoolEdit. Then I "normalized" the entire 6+ hr file to ~-2db so the resulting playback would play nicely on most any amplifier without having to really crank the knob. Got a lot of work done outside while that was happening.
Step 4: This turned out to be a non-step. I use an app called GrooveMechanic to eliminate pops, tics and hiss-noise from my LPs, etc, digitizings and thought I needed to do a hiss reduction on this project. I determined that hiss/noise was not necessary ... nice and clean after normalization.
Step 5: Split 6 hour block into 1hr parts, for conveinence sake only, and save as separate WAV files. No big deal. Time consuming for an old PC though. More seat time.
Step 6: ENCODE WAV files to MP3 format. The streaming bit rate was 64k so it made little sense to encode at anything better than that. (Yes, I essentially re-encoded an already heavily compressed stream yet again ... the result is very acceptable for my particular use.)
I have the MP3 encoder plug-in for CoolEdit so I just wrote a batch script to save all the WAV files I created to MP3 files encoded to 64kbps sampled at 22050hz stereo.
FYI, the minimum bit rate that I have heard being "acceptable" for "near CD quality" in MP3 format is 128kbps @44100hz sampling rate, 16bit stereo. That yields a file size of ~1MB/min. Via arithmetic, my files are ~0.5MB/min ... which should get me ~20hrs/MP3 CD ... or slightly less on a 512MB MP3 player.
I hope the accounts my weekend project has been of some help to you Soundguy and maybe others. The job at hand is, getting the job done, whatever the job is.
MikePA, great to hear from you! Where were you during the many land surveying discussions recently?
Cheers! :)
/ making mp3 files #26
WOW!!
Now another hard question. How long will it be till the music CD is no longer sold in stores? Heck, I still refer to music CDs as "records".
Cheers Coffeeman
/ making mp3 files #27
coffeeman said:
WOW!!
Cheers Coffeeman
Well, I don't buy store-bought "CD's" any more. When I want specific tunes, I go to the Wallyworld website and choose those tunes individually and have them burn me a custom CD. Now, you may ask, "why not just download from Wallyworld"? Answer: I don't like anybody telling me that I have to use THEIR software to download and play the files I want. I can wait for the CD in the mail then, encode as I see fit, if at all ... bottom line, my choice.
Another FYI: The kids that bootlegged music by exploiting the [so called] MP3 format have brought the world more choice and descretion in their purchases. No need to steal, but no need to rob the public by forcing purchase more than they want either.
FYI2: Just for those that don't know, MP3 means "MPEG1 audio layer 3" ... a nicely extracted use of one of the audio streams available with the old MPEG1 video format.
I know there are many folks that have a lot more knowledge on this subject than I do ... but I've mostly spewed all I know on the subject, short of a few tricks applicable to specifuc subjects.
/ making mp3 files
Thanks for the link, deffinately along the lines of what I was looking for. Am trying audactiy as well.
Soundguy
MikePA said:
I agree.
Here's some help.
/ making mp3 files #29
Soundguy,
I bought some software that was really ideal. of course I had a hard drive crash and lost it but when i have a chance I will go look it up. The whole purpose fo the software was that it was basically a coverter package. It would convert any sond (and I think movies?) format into a different format. It was really specialized software. What I liked about it is i would get books on tape (well actually they were books on CD) and i converted them into mP3 files which were much smaller file sizes than the recorded format on the CD's. Once I converted to MP3 files I wold burn a CD and have the whole book on one CD. Literally take a Book on tape form the library that was 10 CD's in length and convert it to one CD using MP3 files. the reason i liked this software was for audio books you don't need the high fine fidelity and this software let you select a recording "fineness". To my ears i couldn't tell the difference at all in sound quality in the voice of the person readig the book from the original cd to my lower format conversion. It was very nice to go for a vaction and take along a few CD's that each had a book on them, rather than haul around th 10CD book.
If you have not checked out your local library for audio books try it. In particular there is one author i love to listen to his books as audio books -Larry McMurtry. He won a Pulitzer prize for Lonesome Dove. My all time favorite audio book is Boone's Lick . The man who reads the story if fantastic.
I do not eel guilty for copying library audio books as they are for my own personal use and i don't distribute them. It is just a conveninece factor. I would go and get a bundh of them spend a night or 2 copying them, and then at my leisure listen to them. That way i did not have to make so may trips to the library. Another good audio book is "The secret life of bees"
in fact over here in France I listen to chapter a Day from Wisconsin Public Radio. The keep 7 days worth on their website so if you miss a day you can go back. They read really good books at Wisconsin Public Radio - Home then Chapter a day. We jsut finished one about a dog. I have yet to go today but i knwo they are starting a new book today. Chapter a day at Wisconsin public Radio is very nice.
When I ahve a chance i'll go find that software I used for converting audio file formats, it was really good.
/ making mp3 files #30
It really depends on what version (early 10 or 9) of wmp you have. If you get your win updates then you have got what they call "copyright protection" installed on your WMP. To get a .wav file to burn via wmp you needed to have taken it from a CD you put in the computer so that it "knows" you own it. Now if for some reason you have lost your database for wmp then it "forgets" that you own it. This is why you would backup your database.
I must say that I am very partial to my music and would always buy my music on vinyl, CD, SACD, DVD-A or DTS 5.1. I like to have the full bandwidth of my music. I also spend as much (or more) on my audio equipment as I do on my tractor.
I work on computers for a living (and a lot of other things) and I am what they call a MCP. I am not here to say anyone is wrong at all. I will not get into the whole mac thing as most will not like what I have to say. I will however say that make the best out of what you have. There are lots of "free converters" out there that will do what you want them to do. WMP will too. Software is a choice and "ALL" of it is "BUGGY". If one thinks different you have not used it enough. Nero, WMP, disk imaging programs is what I use do put music on my computer. BTW I have a music server with all .WAV files so I can play it on my music system. I also do video as well.
As far as Itunes I do not like it because it is very "tight" as to what you can do with your music. I want to own my music and I do not want anyone telling me how I can use my music. (This is my preference.) I do not want to start a war by any means. so please use what works for you. It is all in how the program works for the individual.
If you would like more info please ask.!!:D
If it were not for computers we would not be having this conversation.!!:D
Shane
/ making mp3 files
I have WMP 10.. but so far it does not give me the option of reading one filte type and saving as another..e tc..
Soundguy
2020 Deere 670GP (A64126)
2020 Deere 670GP...
2008 Ford F-450 Flatbed (A62613)
2008 Ford F-450...
19 gal Portable Sandblasting Cabinet (A66408)
19 gal Portable...
2016 WESTERN STAR 4700SF DUMP TRUCK (A59914)
2016 WESTERN STAR...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
