Making gas cans great again
   / Making gas cans great again #81
I like the tire valve idea, but would be concerned that gas would adversely affect the rubber.
A proper push-in vent cap from Amazon is much cheaper, easier, and better.
   / Making gas cans great again #82
I buy old gas/diesel cans at yard sales. I stick to the metal ones.
   / Making gas cans great again #83
Maybe it's different in Canada, or maybe I'm in the minority, but I spilled a lot more with the old cans. I think a lot of you are remembering the good old days with rose coloured glasses. My gas cans leaked at the base of the nozzle. The plastic bendy straw style leaked at all the joints. Turning a 5 gallon can upside down as you tried to get it into a small hole guaranteed some leaked first - even with a funnel.
Then there is the fact that with this ethanol gas, it has a shelf life of months, and it gets much worse when vented. The automatically sealing cans keep the gas fresh longer (although steel is really the way to go and I saw a link for some nice ones on page 2 maybe?)
I love the auto sealing nozzles, especially for filling chainsaws. Yes it means a little extra time, but I'm saving that in spilled gas and keeping it fresher. I'm happy with the tradeoff.
I also use an electric pump for larger jobs now. Spills less again and it's easy.
I get my water directly out of a well without any filters, so I appreciate my ground having less spills.
*pro tip, when I fill I try to fill on the gravel driveway and when stuff did/does spill (still using some 30+ years old cans), lighting it on fire helps get rid of it quickly
   / Making gas cans great again #84
This topic is one of the reasons I like the quotes by Ronald Reagan
“The most terrifying words in the English language are: I'm from the government and I'm here to help.”
― Ronald Reagan
“Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves.”
― Ronald Reagan
I love Reagan and have been to his presidential library 4 times.
   / Making gas cans great again #85
What unemployed cats?
Deleting DPF will eliminate the need for the SCR which isn't quite the same thing as a gasoline catalyst.
I was being humorous, which you missed I believe.
I, and most people, tend to think DEF smells like cat piss. So if DEF is done away with, the cats are unemployed from pissing in the jugs.
   / Making gas cans great again #86
I think you are in the minority. I don't usually spill with the new cans, but being older and holding up a 5 gallon can that takes way longer to pour than the old vented ones sucks. I'm in good shape now, but I can see a day in the future where I won't be able to. I'm also starting to get pissed off every time I fill something and have to wait so long to finish as the air bubbles into the can. So what do I do? Get smaller cans and spend even more time filling up? I am sure I probably spilled a little with the old cans, but the spring loaded nozzles that fell apart spilled way more than anything else I ever used. I do not have any of those now. I do agree that you need a tight seal for the ethanol to keep from getting water in it longer, but what I remember in the old days had a vent that closed and a cover on the spout that screwed on. Maybe they didn't have those in Canada?
Remember your puck will sink when the ice melts... and I'm just kidding on that one so don't take it wrong. We are hockey fans in Texas and there is no ice here.
   / Making gas cans great again #87
The ones I have lasted for years before they started cracking, never leaked anywhere as you could bend the spout and place it in the tank of whatever you're filling before upending the gas can.
Now as someone pointed out, they're too small diameter at the base flange and leak like a sieve.
This is the one I was talking about, notice..."Discontinued"
   / Making gas cans great again #88
Silly. Everyone knows it is horse piss.
   / Making gas cans great again #89
I just take the spout off and use a funnel. Much faster.
   / Making gas cans great again #90
I just ran into another design problem on gas cans. I have one of the push button type cans that someone gave me but I had never used. I needed to drain the gas out of a project car, so I needed all the cans I could find. When I took the spout off, I found a permanently mounted screen in the can. I was able to pull it out with a little work, a screwdriver and some pliers, but think about the concept. They put in a filter to catch any crap when you fill the can, but it will go right into the tank when you use the can to refuel anything. The only thing it does is keep the can clean.
VERMEER FEED ROLLER (A58214)
VERMEER FEED...
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
