Making drain holes in old tires
   / Making drain holes in old tires #1
BeezFun
IL
Kubota B2710
I use old tires to hold down tarps on my manure pile. They fill up with water, can't get it out. I tried drilling holes in the tire, the rubber just closes up. Same thing when I used a .22 to shoot a hole. Any ideas on how to make a hole big enough that won't clog up, like at least 1/4" in diameter? I was thinking maybe heat up something with a torch and burn a hole, not sure if the steel belting will stop that.
   / Making drain holes in old tires #2
Metal cutting hole saw and a portable drill. :thumbsup:
   / Making drain holes in old tires #4
Yep,
I hang an old tire on the brick frame of my pallet forks as a bumper, it has about half dozen 1 inch or so holes in it that I drilled with a hole saw, probably 2 inches between centers.
If you have a SHARP hole saw it will zip right through steel belts, just be careful handling the cut out plugs.
After a year or so the steel ends rusted to dust, so cleaning out leaves isn't a hazard.
   / Making drain holes in old tires #6
We've done it the same way as bigfoot62 says for years. Drill them in the crown of the sidewall. Works best. May your pile be big and rich
Why didn't I think of that. I actually moved my hole saws to get at the drill I tried to use.
Tnx to all for ideas and entertainment
   / Making drain holes in old tires #9
I've used a log splitter.
3HP Electric Fans (A50854)
3HP Electric Fans...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
