Making drain holes in old tires
   / Making drain holes in old tires #1
BeezFun
IL
Kubota B2710
I use old tires to hold down tarps on my manure pile. They fill up with water, can't get it out. I tried drilling holes in the tire, the rubber just closes up. Same thing when I used a .22 to shoot a hole. Any ideas on how to make a hole big enough that won't clog up, like at least 1/4" in diameter? I was thinking maybe heat up something with a torch and burn a hole, not sure if the steel belting will stop that.
   / Making drain holes in old tires #2
Metal cutting hole saw and a portable drill. :thumbsup:
   / Making drain holes in old tires #4
Yep,
I hang an old tire on the brick frame of my pallet forks as a bumper, it has about half dozen 1 inch or so holes in it that I drilled with a hole saw, probably 2 inches between centers.
If you have a SHARP hole saw it will zip right through steel belts, just be careful handling the cut out plugs.
After a year or so the steel ends rusted to dust, so cleaning out leaves isn't a hazard.
   / Making drain holes in old tires #6
We've done it the same way as bigfoot62 says for years. Drill them in the crown of the sidewall. Works best. May your pile be big and rich
Why didn't I think of that. I actually moved my hole saws to get at the drill I tried to use.
Tnx to all for ideas and entertainment
   / Making drain holes in old tires #9
I've used a log splitter.
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A50854)
VERMEER VACTRON...
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
