Making drain holes in old tires
   / Making drain holes in old tires #1
BeezFun
IL
Kubota B2710
I use old tires to hold down tarps on my manure pile. They fill up with water, can't get it out. I tried drilling holes in the tire, the rubber just closes up. Same thing when I used a .22 to shoot a hole. Any ideas on how to make a hole big enough that won't clog up, like at least 1/4" in diameter? I was thinking maybe heat up something with a torch and burn a hole, not sure if the steel belting will stop that.
   / Making drain holes in old tires #2
Metal cutting hole saw and a portable drill. :thumbsup:
   / Making drain holes in old tires #4
Yep,
I hang an old tire on the brick frame of my pallet forks as a bumper, it has about half dozen 1 inch or so holes in it that I drilled with a hole saw, probably 2 inches between centers.
If you have a SHARP hole saw it will zip right through steel belts, just be careful handling the cut out plugs.
After a year or so the steel ends rusted to dust, so cleaning out leaves isn't a hazard.
   / Making drain holes in old tires #6
We've done it the same way as bigfoot62 says for years. Drill them in the crown of the sidewall. Works best. May your pile be big and rich
Why didn't I think of that. I actually moved my hole saws to get at the drill I tried to use.
Tnx to all for ideas and entertainment
   / Making drain holes in old tires #9
I've used a log splitter.
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
KLEIN TOOLBOX (A50854)
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
