Making concrete from crusher run?
   / Making concrete from crusher run? #31
Around here, it's hard to get them to deliver less than 6 yards, and there when the whole aggregate shortage made it hard to get concrete, if they would deliver less than 6 yards, they made you pay for 6 yards...
Those kinda setups are good for a few panels of sidewalk, home owner stuff, or a 9 ft x 9 ft shed pad.
Even bigger jobs will have a few things like replacing broken curb or broken sidewalks.
But, as you pointed out, it is really only worth it as the customer if it's pretty dang local.
   / Making concrete from crusher run? #32
Concrete needs clean sand. It's usually washed first. I don't know the process but there's tons of river sand available cheap in Vancouver, B.C. and they haul in other sand for concrete. Bricklayers are also very particular about it.
I used one of those rental trailers once to do about two yards or less. Decided it's not worth the savings. When we needed a lot of concrete for fence posts, I'd bring a couple of yards of navyjack (sand and gravel mixed at the yard for concrete) and bags of portland cement. We'd mix it in 5 gallon pails with a home made mixer like a drywall paddle but smaller.
   / Making concrete from crusher run? #33
When I use that mixer I’ve always just used bagged concrete but it’s went up to like $7 a bag.
$2.57/60lb here.
Comes out to $150/yd
   / Making concrete from crusher run? #34
$2.57/60lb here.
Dont know about Menards, but I avoid quikcrete from Rural King and other "farm" places, as it's often sat there for many months, and you'll get a lot of half hard bags.
Home Depot has like 15% off per bag when you buy the entire pallet; I think Lowes makes you buy two pallets to get the bulk discount. I have also had Home Depot want to charge me a $15 pallet deposit. I told them, then instead of setting whole pallet on trailer, yall can stack each bag; they waved the pallet fee...
   / Making concrete from crusher run? #36
A couple months ago price was almost $6. I checked today and thought if it's under $4 time to move on it. $2.57 even better so picked up 40 bags.
I just read the fine print - Menards will knock off an additional $.03 for volume pricing. Huh.
   / Making concrete from crusher run? #37
Looks like Home Depot is $4.48/60#; but I'm sure that varies store to store
   / Making concrete from crusher run? #38
3.88 for 50 lb. and 5.98 for 80 lb local Lowes. 10% off with bulk purchase
   / Making concrete from crusher run? #39
That's really pretty good at $154.20/CY; but also a lot of work. Those new "Muddmixer" mixers look like they make it easier/faster, but there is no getting around it still being a lot of work.
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59575)
2020 INTERNATIONAL...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
