Making a Tractor Road - I've got questions
   / Making a Tractor Road - I've got questions #32
Couple options.
When it's wet out, just don't use the tractor - farming is a sunny day sort of thing. :)
Get the field road to grass over - if you don't drive on it every day, a good established sod can carry a lot of weight.
Build up the field road - crowned - so it is higher than the ground surrounding it.
Put drainage across it so water on the uphill side can get to the downhill side in the low areas.
Cover roadbed with a good grass if this is more seldom used, or cover with some gravel if it is often used.
You can get all fancy, or keep it pretty home-spun simple, but basically some combination of this will be your answer.
--->Paul
   / Making a Tractor Road - I've got questions #33
In looking at your pictures, it appears you may need to use a combination of approaches if you don't want to go with a lot of rock. One thing I would do first is move the road away from the pond if at all possible. We have one that close to our pond, but it is solid and it makes me nervous. We can't move it without a lot of expense as it has a culvert and was built too narrow by the people who put the pond in. We are going to rent an excavator some day and fix it, but there are LOTS of projects ahead of it.
Rerouting in some areas may also be an option.
With the cost of rock and good culverts, finding a cheap way to fix your roads is going to be hard.
We had a RR abandoned on our property and were able to get a lot of rock free.
Not thinking ahead, my father in law had tons of rip rap buried when he had someone come in and remove one of the bridges. I sure would like to have that now.
   / Making a Tractor Road - I've got questions #34
Dan,
The doc was interesting and gave me some ideas. I have another water/road problem I've not brought up yet that maybe those ideas might help...
There is very limited space alongside the pond and the road to place rip-rap, but I like the idea.
I also am VERY interested in ideas for how to level this section while I am doing this. because the idea I am MOST scared of is winter with snow/ice and the tractor sliding sideways... and SPLASH... I'm not even sure how deep the pond is there... I do not want to test it with my DK50... The "slope" makes me worry...
I do have an alternative route I can (and will on occassion) take, but it tears up the visible yard areas. I really need this to be an effective road. maybe even eventually one my pickup with a trailer of hay can use.
Thanks,
David
From the photos, it seems you have water running down the road as well as across the road, downhill from an outbuilding and towards the pond.
The water on the road can be handled by crowning the road, water bars, and/or ditching. We have problems on one section of our driveway because the driveway only has a couple of inches of gravel and as a result the driveway is at grade level or maybe a bit above grade. We need to add another inch or two of ABC to keep the water off the driveway.
I suspect you might have to add either gravel or dirt to be able to crown part of the tractor trail because of the location of the outbuilding and pond. Water bars might work too.
I used rip rap to hold the gravel in place over the culvert we have at the start of the driveway. The ABC does not move much anyway but the rip rap makes sure it does not move. I could have used rocks found on our place but time was more important than saving a couple hundred dollars. Some day I want to cover the rip rap with rocks from the property to just make it look more natural. :D
The section of the road near the pond, which makes me nervous too, I think could be leveled with rocks or rip rap on the pond side and ABC/gravel/dirt uphill from the rocks/rip rap. I think the rip rap on our low section would keep the tractor tractor from sliding off the driveway. The rip rap is not stacked very high above the gravel. May be single or double layer that might be 12 inches tall. It seems like you need a culvert there but it still is hard to tell from the photos. There are design rules on how big of a culvert one needs based on the area drained.
You might be able to get away with that French Blankety Thing previously mentioned. :D
Later,
Dan
--->Paul
Paul!
Say it is not so!
David
RRR,
I will look at that idea of moving the road over away from the pond. There are only a few feet between the road an the outbuilding, and there are a couple trees there also I would need to grind stumps etc...
I do not want to weaken the foundation of the "barn" though... I suspect I can get a foot, or maybe 18" max.
My biggest concern is without rending an excavator, I'm not sure I will have good enough footing to dig it up with the tractor, because the only ground to work from is the current road.
I will look at this when I get home tonight.
Thanks for the thought!
Be well,
David
   / Making a Tractor Road - I've got questions #37
RRR,
Be well,
David
That sure is a problem. When my father in law first bought this farm in the late 80's, our road was very similar in one place. We got by for quite a while as we had more projects, getting ponds dug, building roads on another farm etc., but one day, I put my truck over the edge due to the mud. It was about a 20' drop off into a dry creek. I was going real slow and the truck hung on the lip.
I had to SLOWLY climb out of the high side window dragging my old bag phone with me so I could find a place with a signal to call for help.
My brother was able to hook up and pull my truck out, but it was a toss up as to whether it was going to go the other way.
We couldn't move the road very much either, so we leveled it out and put a lot of crushed rock on it.
We put all of our culverts in with a FEL, but for a small area like that an excavator sure would be nice.
I am sure some of the members with more expertise can come up with something that will work for you.
   / Making a Tractor Road - I've got questions #38
Moss,
I think there are some good suggestions on here. I would maybe add rip rap (rail road size rock) first then gravel on top. Like others have said I think you may need several methods on your roads.
Moss,
Would you just put the rip rap down on the dirt and add the gravel on top? Won't that all just sink into the clay?
Not sure I am following you here, sorry.
I would LOVE an easy fix...
David
You could always just build a corduroy road. It doesn't sound like your bog road is that long.
How big of logs do I need to use, and how long might it last? I'm thinking about using a corduroy road solution for the turn off bog spot and I'm wondering how big the "logs" need to be... Might actually be more work cutting and limbing the logs than digging and using gravel.
David
TMA (A49461)
TMA (A49461)
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
(11) 8' Treated Posts (A50515)
(11) 8' Treated...
19010 (A48082)
19010 (A48082)
