Mahindra tractor over heating, Please Help
/ Mahindra tractor over heating, Please Help #1
sammie
ms
Mahindra tractor
I have a 2014 Mahindra 6110 with 800 hours on it, that has been over heating every time I cut my grass with my 12 ft. Rhino bush hog. This problem started in the first of July this year when the plastic fan and belt broke for no reason. Right after my dealer replaced the fan and belt I started getting a Squealing sound coming from my AC compressor because the compressor was locking up. If I turned the AC on and off 3 or 4 times the Squealing sound stopped and the AC would work, BUT my tractor would over heat within 30 minutes of grass cutting with the AC on. I always ran my Tractor in Medium and the gear in number 1. I have run my tractor for the past 4 years like this with out it ever over heating. My Dealer told me to run my tractor in Low and number 1 gear till they figure out what is going on with my tractor and its over heating problem. I did as my dealer suggested and ran my tractor in Low and 1, and now it took 40 minutes this time for my tractor over heat again. I found if I run my tractor in neutral at 1700 rpm and with the pto shut off and the ac shut off that I can get the Temperature down from hot to 1/2 in 4 or 5 minutes and I can continue to cut my grass for another 10 minutes before the tractor over heats again. Now out of Frustration I tried something new. I got my tractor temperature back down to 1/2 now, and when I turned the ac on the temp immediately when to 3/4 before I shut the ac off, I did this 4 times and each time it did the same thing, it immediately when from the 1/2 to 3/4 before I would shut the ac off, because if I didn稚 shut the AC off, it go up into the hot. This all happened while my tractor was sitting in neutral. So I thought ok lets try running the tractor with the ac off. I put the tractor back in medium and number 1 in the gears, and I had to open all the windows like I have had to do many times before, but with the ac off I was able to completely cut all 6 acres of grass around my house with the temperature now just below 1/2 and no over heating. I am Sorry for the long post, but I believe my AC compressor is BAD AGAIN? If this AC compressor is bad and this is what is causing my over heating problem, This will make the THIRD AC COMPRESSOR in 4 years that had to be replaced. If any of you think my AC compressor is bad, My Question to you Is this NORMAL for Mahindra tractors to burn up the AC compressors? A new AC compressor is around $700.00 to 800.00 for the compressor alone, not counting labor to put it on. Please Help me, Is this NORMAL for Mahindra tractors to burn up the AC compressors in such a short time? I Thank you all for any help.
/ Mahindra tractor over heating, Please Help #2
G'day it is not normal for any A/C compressor to last that short a time, back to basics first is the fan belt tight and sitting well up in the pulleys? Is the air flow through the radiator/condensor nice and clean? Do you have access to a compressor to blow the fins out with air? Just a few things to start with as for the price of the compressor you will be able to find the same compressor online or aftermarket alot cheaper than the dealer
Jon
/ Mahindra tractor over heating, Please Help #3
Appears the guy has 3 different threads about the same subject, might be an issue of not being able to find the first one an not being notified of responses
banjodunn Thank you for your reply. My tractor is still under warranty and my dealer installed this second AC compressor lest than a year ago. They been out here checking my tractor out and said the belt is good and tight. We clean both the radiator and screens often. I thank you for your help
AllDodge I am sorry sir if my posts don't set well with you. I am desperate to find a answer to my over heating problem and I have been getting replies on all my posts in the different threads. This is a great forum with many great members here willing to help me out. I Thank all of you for all your help. Sammie
/ Mahindra tractor over heating, Please Help #6
You may have two problems. One with the AC compressor and one with the engine cooling circuit. Cooling system problems maybe caused by a stuck closed thermostat, clogged air side radiator passages, loose fan/water pump drive belt, lower rad hose collapsing at off idle rpms, pressure cap not functioning properly, clogged air filter, restricted exhaust, leaking injectors,etc.
Systematicly check these out.
Jerry/MT Thank you for your reply. I will have it checked out like you have written.
Land Hero Mini Skid Loader (A66408)
Land Hero Mini...
Skid Steer Power Broom (A65640)
Skid Steer Power...
Unverferth Lift Assist Wheels (A65640)
Unverferth Lift...
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
