mahindra quick hitch question
/ mahindra quick hitch question #1
notacos4u
Schaghticoke, Ny
Mahindra 1533
I currently purchased a Mahindra quick hitch and 6' box blade for my Mahindra 1533. I was wondering if it is sitting correctly because the bottom pins don't seem to rest on the quick hitch support. I have the top hook attached at the lowest point on the quick hitch, and not sure how to potentially correct this. Do I need bigger bushings for the 6' box blade? You would think when purchasing A Mahindra box blade and a Mahindra quick hitch, things would match up correctly. Thanks for everyones assistance in advance. Jim
/ mahindra quick hitch question #2
Normally when using a quick hitch, bushings are used.
A cat 1 quick hitch the implement will get bushings cat 1 to cat 2,
a cat 2 quick hitch the implement will get cat 2 to cat 3 bushings.
/ mahindra quick hitch question #4
You need to buy some bushings. Cat 1 to 2 and Cat 2 to 3. Put them inside each other. This will work if you are running with a clevis style of implement. If you have to pin style you need this. Quick Hitch Adapter Bushing Kit - Category 1 Make sure you buy enough for all your implements so you are not switching them around.
Adams 16T Tender Body (A63688)
Adams 16T Tender...
Vicsec 30in. Grading Bucket Mini Excavator Attachment (A61572)
Vicsec 30in...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
