Mahindra mForce 100P - Three point trouble....
   / Mahindra mForce 100P - Three point trouble.... #1
Stephen21
Mahindra
Hello Everyone,
I am glad I found this place. Plenty of great info.
To get one thing out of the way.... Yes, I am stupid. :)
The cotter pin that secures the big pin that connects the lift arm to the lower arm came out. That allowed the lower arm to drop to the ground. Not a huge problem.... Until I backed over it....
Here are some pics of the damage:
   / Mahindra mForce 100P - Three point trouble.... #2
Ouch, may want to be sitting down when you price out the pin at the front. It's the draft sensor.
   / Mahindra mForce 100P - Three point trouble.... #3
Hey...you just added some "character" to your tractor. I have several of those of various origins on mine. ;)
I feel pretty good about putting it back together except for one (BIG) item.
The shaft that the forward end of the lower bar pivots on sheared off. I know that shaft plays a part in some of the fancy functions that I don't currently use.
Splitting the case to replace the shaft looks like it would be a big project. Definitely beyond my skillset.
Could I fab a new "pivot" for the lower arm and run with it? Or will the sensors and computer get unhappy and refuse to play along?
   / Mahindra mForce 100P - Three point trouble.... #6
I wouldn't even worry about the draft sensor.
Getting the other bolt pieces out and praying that the case isn't cracked.
   / Mahindra mForce 100P - Three point trouble.... #7
As long as the hitch is still moving up & down, yes. Should only affect draft function. Only had that happen on one & that was years ago. They just bought the part since they used a mounted plow on it. Similar situation as you and it didn't crack the case. YMMV. Edited to add, that is a blind hole. Doesn't go all the way through the case.
   / Mahindra mForce 100P - Three point trouble.... #8
Here is an exploded view of your lift arms;
part #13 is a bolt M16x120 so almost a 5/8 x 5"long bolt,
then they are calling #71 the draft sensor which looks to be the pin that locates the lift arm.
THANK YOU!!!
The advice and the parts diagram are both appreciated.
It looks to me like I may be able to replace the broken shaft Without major disassembley.
Yes, #71 is the broken shaft I am referring to.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2017 Mahindra Emax 22 Tractor (A59814)
2017 Mahindra Emax...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2844 (A58376)
2844 (A58376)
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
