Price Check Mahindra 5530 & 6530 ?
/ Mahindra 5530 & 6530 ? #21
Brian, that grapple pic depicts exactly the kind of stuff I have to pick up and move.:thumbsup: What tractor & grapple is that in your photo? Nice!
BTW, there is a part of me that is thinking: "buy a used bobcat to finish the clean up and a basic tractor to maintain farm". Added together, those would undoubtedly cost more than just buying an upgraded tractor.
That is my Mahindra 7520 and the grapple is this model in the 81" version. When deciding on a grapple, most guys on TBN are convinced that you only need a 48" light weight model, and they are probably right when a guy has less than a 2500lb lift capacity. But as the tractor gets bigger, you can start using the grapple for other things other than just moving loose stuff.
One of the problems with a skid steer is ground clearance, need to keep that in mind. ;)
cederstrand, have you ever looked at a 5035? They are a very nice tractor, I know that if I needed a tractor of that size, it would be at the top of my list of tractors to be considered.
Can't find a 5035 on the Mahindra website, at least not the one at: ::: Welcome to Mahindra Tractors ::: Couldn't get yout link to work. :confused: Hey, just looked it up on other sites. Seems to be a compact tractor with less HP than others I've been considering.
/ Mahindra 5530 & 6530 ? #23
When I type in www.mahindrausa.com ,all I get is NetAssistant. When I search for it and click on the link, I get that same dang NetAssistant page. Why do none of these links work? Gurrr!
Never mind. Think I found it: http://www.mahindrausa.com/Home Maybe it's my browser...keep getting that blasted search.freeze.com (NetAssistant) bs. I'll try tomorrow.
/ Mahindra 5530 & 6530 ? #26
I just checked the link, works fine here. :confused: The tractor with loader is about 6500lbs. Put a good 1000lb box blade or rear blade on it and fill the tires and you would have an 8500lb machine working for you. That is about the only way that I see you getting a power shuttle from Mahindra. I believe that the 8500lbs is all that you would be able to get with any of the other tractor makes that you are considering. Typically on the weight of tractors, Mahindra's are as heavy or heavier than everyone else's.
/ Mahindra 5530 & 6530 ? #27
That there is a New Holland BLUE Mahindra 7520.:laughing::laughing::laughing:
hugs, Brandi
Took a trek into the smaller section of future pasture, across the creek behind my house. Man, there is a LOT of down tree branches and stuff that will need to be cleaned up. And that's before the stumps can be removed, as they are hidden under everything right now. Sure looks like a lot of root-grapple work. Much more than I had thought.
So, exactly what is the "minimum" tractor that will be required for such work? And it had better be mighty sturdy considering how much of this work is on a hillside. Is the Mahindra 6530 really to small for a decent root grapple?
And how hard is it to learn to use a loader on a moderate hill if you have to clutch to change direction? Think beginner. It has been many years since I drove any real tractors. Rob
/ Mahindra 5530 & 6530 ? #29
Rob, if you are working on hillsides, no matter what tractor you get as long as it has inflatable rubber tires, plan on getting them filled. Any tractor will be waaaaaaaaaaaaay more stable with the tires filled. I would have all 4 filled if it were me. In fact all 4 of mine are filled on both my 7520 and 3215. From what you have said, (we have not seen) I believe that the 5035 is plenty big (can be configured to be over 8000lbs) to do everything that you have described. You can get it with an HST so no need to even worry about using a clutch, or the power shuttle, again no need to worry about a clutch. Get yourself a nice 72" grapple and go to work. When you do get a box blade, be sure that you get something that is North of 1000lbs and be sure to get at a minimum of 2 rear remotes no matter what tractor you end up getting. You will want top and tilt cylinders for your 3pt hitch when you are grading.
There are many here on TBN that would say that you should get a smaller grapple, since you are just going to be moving loose stuff. They may be right, but I would still get at the minimum a 72" unit if it were me.
Thanks, Brian. Are you sure the 5035 (@ 49.5hp) has enough "oomf" for a decent grapple? On the site where your grapple is sold, they suggest a 60hp tractor. So, are you recommending one of their regular grapples for the 5035? Seems like the 5035 wouldn't work with yours plus a load, unless I'm missing something. This tractor has a listed weight of 4,939 lbs. I'll drop in on the Mahindra dealer sometime this week and pic his brain.
Oh, any idea what these tractors sell for? Cheers!
/ Mahindra 5530 & 6530 ? #31
Not that it matters, but where do you see the 60hp recommendation? I do not see any hp recommendations. And yes for moving loose stuff just get their std duty grapple built with 3/8" steel. The 5035 has a loader lift capacity of 2700lb. Even with the heavy duty grapple you would still have plenty of lifting power. Yes the tractor weighs 4939lbs, then add 1400lbs for the loader and 1000lbs for a rear 3pt implement and 1000lbs for filling the tires with fluid and now you have an 8000lb + monster. Yes a bigger tractor makes some of your chores easier to complete, but also cost a lot more $$$$. I personally would get the 5035 vs any of the 30 series tractors for what you have said that you will be doing.
Just my :2cents:
Fair enough. Will look into the 5035 this week. Thanks!
[We recommend a 60 HP machine or stronger to use this grapple.]...
Skid Steer Extreme Root Grapple
Edit: Just checked the Dealers site and he doesn't have the 5035, although I'm sure he could get one. He does have a 6010 HST cab and 6120 Shuttle cab.?? -Rob
/ Mahindra 5530 & 6530 ? #33
You do not need an extreme grapple. Those are really intended for skid steers. Even if you were to get a heavy duty unit you would not need that much grapple. In my opinion the regular 72" unit would be very good for your clean up. Again just my opinion, but stay away from any of the cab tractors. With your working conditions as I understand them, you will end up with broken glass and it is very costly to replace. Before you purchase any tractor, be sure that you set on it and have a feel for how everything is situated for you. Sometimes there are small things that you can live with but annoy you. You are buying a new tractor, get one that fits you and that you are comfortable with. You shouldn't have to get use to anything, get one that fits you right to start with.
Will try to upload a couple pics for you. One shows a snapshot of what is on the hillside. The other is an example of what needs to be removed from the lowland. Weeds are over 6' tall while the green saplings (in the photo) are much taller. This is a very small section of property that needs clearing, but there is more there than meets the eye. Some of it is in boggy land, too.
The 5-8 acres worth is elsewhere and mostly stumps (which will be removed by trackhoe) so should be handled well with just a boxblade. Will have to look for a pic of that area.
One more pic from part way up the hill looking down on the small area to be cleared. In the middle of this would be an ideal location for a small drainage trench. Providing I can make one without getting stuck.
/ Mahindra 5530 & 6530 ? #36
You could play it safe and get the heavy duty grapple and still have plenty of lifting capability remaining. But no way would you need an extreme grapple. Again, just my opinion, but what ever you end up with, LOAD THE TIRES. Literally day and night difference with how the tractor performs.
You say a box blade for where the stumps are to be removed. Are the stumps gone and you do not have to deal with them at all, or do you need to move them to get rid of them? That is a perfect chore to do with a grapple. Are you talking about filling the stump holes with a box blade?
I'm confused. :confused3:
I'm hiring a neighbor (with the trackhoe) to dig out all the stumps. After that, I can either have him pile them for burning or (as you pointed out) I can do that with a grapple. Hadn't even thought about that until you mentioned it. Hmmm, no reason I should pay him to move the stumps at all then. That kind of work would be fun.:cool:
I was thinking of using the boxblade for filling the stump holes and then smoothing the entire area out for seeding with fescue.
/ Mahindra 5530 & 6530 ? #38
This would be good. For some reason I was picturing you dragging the stumps around with a box blade and chain and could not figure out why you would want to do that when you had a grapple. :confused2:
A few pics of the larger acreage to be fixed. Can't see the stumps, but trust me, they are there in mass. Most are 12" in diameter and smaller, with only a relative few larger stumps. In the one pic, you can see the hillside (sloping up to the right), the other side of which is the area we previously discussed. LOTS of work for a new tractor to do, no question about that. :licking:
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2015 Godwin CD150M S/A Towable Trash Pump (A59228)
2015 Godwin CD150M...
2010 BENSON/WABASH ALUMINIUM FLATBED (A59905)
2010 BENSON/WABASH...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
