Mahindra 5155 Anyone?
   / Mahindra 5155 Anyone? #661
I pick it up this afternoon, but talking to the tech, he said he did the engine oil change, oil filter, and just changed the hydro oil filter, not the hydraulic oil itself. He said he checked torque on bolts, greased the fittings, etc. Still, I think that price is way low. Unfortunately, I did not mark my filters... after this though, I will be doing all fluid changes myself.
As always, I appreciate your input very much. Thank you Sir... have a great weekend!
10 bucks for each quart maybe $11.
Hydro filter is expensive at around $120
They may have charged you for a full grease cartridge.
Shop supplies.
Oil dsposal
Oil filter is excessive at $40. (Check Nappa for Wix cross overs)
An hrs worth of service at what $120-$140?
Get yourself a good mesh filter funnel to help catch impurities when fueling up.
Good deal I think if they did what they said.
   / Mahindra 5155 Anyone? #662
Shop supplies.
Oil dsposal
All great input!
Once I get the tractor, I will have a detailed invoice and I will share with you all. Fingers crossed that they actually DID the work... :)
   / Mahindra 5155 Anyone? #663
All great input!
They sell these filters in kits at Mahindra that are over $400. It does include the air and fuel filters.
Id still check with Nappa for as many cross over numbers as possible.
This thing takes 12 quarts of hydraulic fluid which can cost you close to $300 at Mahindra.
If you use their kit with their fluids, you're at around $800 just in supplies and parts.
There are cheaper alternatives but don't get cheap hydro fluid.
The cheap ones may contain all of the ingredients that are listed for manufacturers' requirements but what they do not have to state are the AMOUNTS of those ingredients.
You're only having to do this hydro thing every 500 hrs or so and if you average 30-40 hrs per year and the tractor is under cover, you're good for a long time so don't go Wimpy on the life blood.
   / Mahindra 5155 Anyone? #664
Again, great advice.
I plan to keep this tractor as long as I can. I'm not skimpy on maintenance, that's for sure. Quality Oil and Fluids are the lifeblood of the machine, and staying up on the preventative maintenance is ingrained in me (36 years in the Army). Once my shop is finished, I will have a 15k pound vehicle lift and will be able to do it all myself.
I put 60 hours on this tractor in about 6 months, working it hard. I use the grapple more than anything, clearing trees. Starting to use the rotary cutter more and more now that I have the land cleared.
So far, I'm impressed with it.
   / Mahindra 5155 Anyone? #665
You might also check to see about your front axle gear oil. That is supposed to be changed at 50 hrs as well. My bill for that 2 plus gallons was $125.
   / Mahindra 5155 Anyone? #666
Nice !
   / Mahindra 5155 Anyone? #667
Gear oil and hydro oil are the same viscosity of around 30 weight.
They are not measured the same as motor oil so don’t get confused with the 80/90 thing of gear oil.
Gear oil may have a couple more additives but that’s it.
Don’t forget, hydro oil is gear oil as well lubricating the entire center and rear gear parts of the tractor.
   / Mahindra 5155 Anyone? #668
Update on my 5155 (50 hour service).
So, apparently, the only thing that was done was change the engine oil, oil filter, changed the hydraulic oil filter (did not change the hydraulic oil), check torque on bolts, and grease fittings.
They did not use Mahindra oil, they used Rotella.
I picked up my tractor on Friday, and ran it on Sunday for 4 hours.
Everything seems fine, but the grapple seems to be a wee bit "slower" than before. I'm noticing that curling the grapple "up" (pulling the joystick towards the center of the tractor, the joystick gets stuck, and does not release to the center like it used to. Could be an adjustment I need to look at.
I checked the oil before running, it's filled perfectly, and is crystal clear. I also checked the hydraulic oil, it's full as well, and clear.
I've used Rotella for years, never any issues... but I have not used it in a tractor, since this is my first one.
Another thing I noticed, that I have not noticed before, standing in the rear of the tractor, with it in neutral, I hear a clattering, or "rattle" down low. If you pull the rpms back to idle, the rattle goes away. I could not find anything loose, and the PTO is in neutral. I've just not noticed this rattle sound before.
   / Mahindra 5155 Anyone? #669
Sound is peculiar on a tractor. Noises can refer all over the place. Fill the bucket up with dirt and go see what you hear or not in the same fashion you’re hearing now.
Check fender bolts especially where it meets the plastic.
Usually low hydraulic fluid causes a stutter in operation rather than a slowness. It is usually always clear.
Rotella is good stuff. So is the Shell hydraulic fluid if you can find it.
Check your fluids after running as well.
   / Mahindra 5155 Anyone? #670
Have any of you guys had issues with the shuttle shifter popping out of gear?
Our 5155 has been popping out of reverse when the clutch is released. The shuttle shift lever springs forward to neutral and gears audibly grind when it pops out. Holding the lever in reverse doesn't solve it.
It did it to us a couple times the first night we used it. I assumed it was operator error at first, because it seems like the shuttle shifter is not completely engaging into reverse. So I slowed my shifting down and tried being more deliberate. Still popped out.
The clutch pedal had excessive free play, so I adjusted it to spec and hoped this would solve the problem, thinking that possibly the free play was preventing the clutch from disengaging completely, preventing the shuttle shifter from shifting completely into gear.
After using it for a few more hours tonight, it still occasionally pops out of reverse. Much less frequently than before the clutch was properly adjusted, though. I wish it had revealed this problem at the dealership before we towed it home. The tractor had 5 hours on the meter when we took ownership of it. Could the transmission possibly be damaged from those first 5 hrs. of use at the dealership? I'll be calling the dealer on Monday with some questions.
But, have you guys experienced anything like this? Am I overreacting? We live and operate this tractor or a fairly steep mountainside property, so the thing popping out of gear is definitely an issue. I'm going to look at the shift linkage between the shuttle shift lever and the transmission tomorrow to see if there are any adjustments to be made there. Hoping it's something simple for sure.
Mine did the same. Cable came loose under the shifter not allowing it to fully engage. Warranty covered it. They replaced the bracket and changed the cable as it was damaged.
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, 5,888 Hours Indicated, mounted on 2018 (A59076)
2018 Elgin Broom...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
LOT: (10) Wheel Loader Bucket Teeth (A59076)
LOT: (10) Wheel...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52709)
2003 LEEBOY L150...
