Mahindra 1538
/ Mahindra 1538 #2
You'll find it flopping around loose on the left side engine harness. It may be just behind the harness but it looks like a regular port found on a car.
/ Mahindra 1538 #4
You're wecome.
I work part time at a Mahindra dealership. It is one of my pet peeves for Mahindra in that their cost saving notions kind of go the way of Fred Flintstone methodology at times.
The port should be mounted properly on a fixed platform. Yeah it costs extra to do so but if we now exist in an electronics/digital world, I think it's money well spent.
/ Mahindra 1538
Besides another great thanks another problem arose this afternoon. The positive terminal connection has now completely rusted through. I’ve checked all the internet culprits but having a problem marching the original post setup. Any help would of course be greatly appreciated!
/ Mahindra 1538 #6
Yes, that happens to these as well. Poor battery terminal seal from Mahindra using cheap batteries. Seal the bottom of the battery terminals with a spray designed for that and use those felt corrosion resistors you get from the auto stores.
I'll check on part no. tomorrow.
You are talking about the cable connector part correct? 1-gauge-awg-battery-cable-with-ends
Looks like this? pobacafor25m1.html
You can just replace the connector itself with any connector.
/ Mahindra 1538 #7
I just replaced mine with a universal terminal from an auto store.
I smeared dielectric grease all over it as well
You might consider adding a quick connect while there for a battery tender.
/ Mahindra 1538
Thanks, no it’s the actual battery post connection that excepts all the positive wiring onto the battery.
/ Mahindra 1538
Thanks the connector post on the positive side has completely rusted away. So I’m trying in my naive way to find a connector that accepts all the positive wiring there’s 6-7 that needs to be on the clamp! Excuse the poor description. I sent a pic to the other very helpful member.
Thank you.
/ Mahindra 1538
Thanks.
/ Mahindra 1538
Here’s a better pic of the rusted battery clamp/connector.
/ Mahindra 1538 #12
All you need is any clamp style battery terminal.
This link shows how: search
Decorative Turtle Statue (A61574)
Decorative Turtle...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
JOHN DEERE 437E LOG LOADER (A64276)
JOHN DEERE 437E...
(INOP) 2016 POLARIS RANGER 570 EFI RTV (A64280)
(INOP) 2016...
iDrive TDS-2010H...
