M8540 hyd shuttle cable
/ M8540 hyd shuttle cable #1
big bubba
Elite Member
arkansas
M8540
for those MXX40 hyd shuttle owners. had my hyd shuttle cable replaced around 600 hrs due to sticking & not being able to fully engage forward/reverse motion.
currently 825 hrs, no prob. access to cable is complicated (dropping fuel tank, ect) & had dealer do it. anyone out there have any advice on how to access the cable for lube on either end? sure wish the cable had a oil nipple or zerk to lubricate. the tractor is covered most of the time. think the answer is no, but thought i'd ask anyway, regards
ok thanks, will keep in mind. replacement w/labor was around 1k, so will look into it. regards
/ M8540 hyd shuttle cable #4
Basically, it's an aluminum outer body with a rubber inside body and you clamp it on the end of the cable and use motorcycle chain lube in a pressurized can (with the straw) to inject it into the cable. I use it on a lot of different cables as one size fits all. Works on tach cables too.
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
