Loader M7060hdc12 Bent Curl Cylinder?
   / M7060hdc12 Bent Curl Cylinder? #11
Do what PSDStu says if you have insurance and it will cover the repairs. If not - do what 5030 says. I can see your DIY project going south real quick and having to purchase new rams.
   / M7060hdc12 Bent Curl Cylinder? #12
Rods on these cylinders are easy to press straight if you don'r have a press any machine shop should be able to do it for you.
Update: Fixed
I trimmed the corners off of a 4x4 and my son adjusted the bend by moving the 4x4 between the loader arm and cylinder ram, while I operated the curl function. He used an 18" level to keep checking the rams as we slowly worked towards arguably perfect, time will tell.
Thanks for the reply's
   / M7060hdc12 Bent Curl Cylinder? #14
Nice fix. I'm always about simple fixes first. Good job!!
   / M7060hdc12 Bent Curl Cylinder? #15
That IS good news. Just hope you never have to use "the fix" again.
No, I'm "teachable" - won't do that again!
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2014 F-150 STX (A56435)
2014 F-150 STX...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
