Loader M7060hdc12 Bent Curl Cylinder?
   / M7060hdc12 Bent Curl Cylinder? #11
Do what PSDStu says if you have insurance and it will cover the repairs. If not - do what 5030 says. I can see your DIY project going south real quick and having to purchase new rams.
   / M7060hdc12 Bent Curl Cylinder? #12
Rods on these cylinders are easy to press straight if you don'r have a press any machine shop should be able to do it for you.
Update: Fixed
I trimmed the corners off of a 4x4 and my son adjusted the bend by moving the 4x4 between the loader arm and cylinder ram, while I operated the curl function. He used an 18" level to keep checking the rams as we slowly worked towards arguably perfect, time will tell.
Thanks for the reply's
   / M7060hdc12 Bent Curl Cylinder? #14
Nice fix. I'm always about simple fixes first. Good job!!
   / M7060hdc12 Bent Curl Cylinder? #15
That IS good news. Just hope you never have to use "the fix" again.
No, I'm "teachable" - won't do that again!
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
Kubota L4701 (A53317)
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
DEUTZ MARATHON...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
2020 Hyundai Santa Fe (A56859)
2020 Hyundai Santa...
