Loader M7060hdc12 Bent Curl Cylinder?
   / M7060hdc12 Bent Curl Cylinder? #11
Do what PSDStu says if you have insurance and it will cover the repairs. If not - do what 5030 says. I can see your DIY project going south real quick and having to purchase new rams.
   / M7060hdc12 Bent Curl Cylinder? #12
Rods on these cylinders are easy to press straight if you don'r have a press any machine shop should be able to do it for you.
Update: Fixed
I trimmed the corners off of a 4x4 and my son adjusted the bend by moving the 4x4 between the loader arm and cylinder ram, while I operated the curl function. He used an 18" level to keep checking the rams as we slowly worked towards arguably perfect, time will tell.
Thanks for the reply's
   / M7060hdc12 Bent Curl Cylinder? #14
Nice fix. I'm always about simple fixes first. Good job!!
   / M7060hdc12 Bent Curl Cylinder? #15
That IS good news. Just hope you never have to use "the fix" again.
No, I'm "teachable" - won't do that again!
2006 TerraGator 8104 (A56436)
2006 TerraGator...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
