m7060 engine warning 50% power reduction
/ m7060 engine warning 50% power reduction #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
Happened after a parked regeneration cycle, it speeded up for about 20 minutes then came back down and we went back to work.
engine warning blink a few times
now stays on reduced power 50%
no buzzer
Dealer says they have to pick it up
/ m7060 engine warning 50% power reduction #2
Well that sucks. Too bad they couldn’t just hook the computer up there and let ya know what it may be/ do a reset and be on your way with any luck.
Keep us posted....
/ m7060 engine warning 50% power reduction #3
Kubota, like Deere, uses a proprietary ecm hookup that only accepts a Kubota Diagmaster scan tool and you cannot buy one. Dealer only item which is why I won't own a post 4 Kubota. Both mine 2002 and 2004 M9's are totally mechanical. Both make in the excess of rated pto power and both are trouble free and have been since new.
/ m7060 engine warning 50% power reduction #4
I wont own any equipment that only a dealer can repair......at a huge cost. I have heard horror stories about JD equipment.
My operator doesn't like to keep the rpm's up. So after the dealer does a forced regen I will have to come up with solution, I'm thinking at end of each day maybe I'll raise the rpm's and let run for 20/30 minutes to burn off soot, then do a shutdown.
/ m7060 engine warning 50% power reduction #6
Start handing your "operator" the repair bills.
/ m7060 engine warning 50% power reduction #7
For my information - what exactly is "raised rpms" for your M7060, Roy? X rpms for X time. Thanks
/ m7060 engine warning 50% power reduction #8
There are ways to “deal” with the DPF and as a bonus, the egr. Costs a few grand but as another bonus you can get an extra few HP and better fuel economy...... once out of warranty I plan to look into it. My VW TDI has been happy breathing easier.
/ m7060 engine warning 50% power reduction #9
/ m7060 engine warning 50% power reduction #10
Tell him if he don't run at rated RPM at least part of the time, you'll fire him...........:laughing:
/ m7060 engine warning 50% power reduction #11
Diesel cars are different. With tractors, there isn't enough volume to make a delete profitable and the EPA is coming down hard on the aftermarket tuners anyway least here in the states.
With tractors there maybe at some point but not now.
My guess is the to burn off the soot 1800 2000 rpm, he only runs about 1000 rpm or less when we moving stuff around, maybe he is worried about running over me.
He is part time worker and trying to get anybody to work who gives a ***** is hard.
/ m7060 engine warning 50% power reduction #15
Ya, everybody stopped manufacturing delete kits & mechanics stopped installing them. At least admitting to it publicly, after lots got hit hard by the EPA. Not popular for tractors anyway as you noted it was a much smaller potential market.
I dislike the extra cost & complexity from all the emissions crap. But I also like breathing clean air & what not. So I don't fight it.
I blame that on our schools and the Dem's that gave us the we all are special and deserve better, instead of nothing comes easy and failure is the best teacher and you do not give up.
I was brought if you didn't break anything you get back on the horse or your a wimp, had a gym teacher that said unless there was blood on floor it wasn't a good day.
/ m7060 engine warning 50% power reduction #17
Fallon, and 5030, I can assure you there are people out there that have tunes figured out for tractors. About the same $ as the car. The amount of jet fuel I burn in a summer doing what we do forgoes any savings to the planet in a few deleted tractors.
/ m7060 engine warning 50% power reduction #18
I have no doubt they are out there, just not as common as on the road diesels.
Thats a pretty bad straw man argument though. Just because somebody else is doing something worse doesn't make it ok for others to do something not quite as bad. Denver had horrible smog issues in the 70s & 80s. Better emissions regulations has all but gotten rid of the brown cloud. DPF in particular gets rid of particulate matter that causes lots of breathing issues.
/ m7060 engine warning 50% power reduction #19
I've seen a couple European places that have the delete kits for the M7060 available but for the life of me, I can't remember who it was.
They would also take the RPM limiter of the 6th gear.
/ m7060 engine warning 50% power reduction #20
You have no choice anyway. Key word 'mandate'.
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
2001 Ford F-150 Crew Cab Pickup Truck (A61573)
2001 Ford F-150...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
