M7040SU underslung/downswept exhaust
/ M7040SU underslung/downswept exhaust #1
Farmer495
Nova Scotia, Canada
CaseIH / MF / Kubota
Does anyone have some up close photos of the underslung/down swept exhaust piping on an M7040SU?
Just curious, have to clear a low door and the vertical stack has to be removed, it's just a straight piece of pipe so I can put a shorter one on it, but wanted to see the factory set up.
/ M7040SU underslung/downswept exhaust #2
Delete. Attachment didn't work. Sorry.
OOPS, maybe it did! Look about 3/4 of the way down the parts diagrams.
/ M7040SU underslung/downswept exhaust #3
I'll try and remember to get a few pics of my m9540 tomorrow. Should be very similar if not exact same set up.
Looks like the entire muffler is different, the one I am looking at is one piece and points UP. I am guessing the factory version uses a totally different muffler.
/ M7040SU underslung/downswept exhaust #6
Like Derek, I'm not sure this will help you. I modified my vertical stack to the down mode. I used the parts from the upright stack to build what I needed to make it a horizontal or lower.
/ M7040SU underslung/downswept exhaust #7
Found these pics on Tractorhouse of a m7040d. Not sure if there is a difference between the "d" and "su" exhaust wise.
*For some reason the tbn app crashes if I try to add more than one pic at a time so I'll have to make a few separate posts.
/ M7040SU underslung/downswept exhaust #8
/ M7040SU underslung/downswept exhaust #9
/ M7040SU underslung/downswept exhaust #10
Thanks DT86 and ovrszd.
Might see if I can either do a couple of 90's to point down, or just get a straight pipe a few inches shorter than the factory one (it's about 5" too long and I don't want to cut it.......)
I don't want to modify the "normal" exhaust since I am fine with the upright pipe most of the time. It's only in the low door for the winter, but still has to come out for use.
/ M7040SU underslung/downswept exhaust #12
I don't recall my elbow being welded on. Memory says it was clamped. Anyway, removed it and used a piece of the vertical pipe to build the sweep I wanted.
I think once you convert it you will not go back to the vertical pipe. I am never smelling exhaust fumes. Only time I even know it's there is if the tractor is running and I spend more than a few seconds at the chain box which is just above where the pipe dumps.
Not sure how handy it would be to go to a muffler shop??? But I'm guessing for $20 they'd build you a sweep for low exhaust. Then you could clamp your elbow back on if you wanted vertical again.
2004 Ingersoll Rand SS-3 Portable Air Compressor (A61572)
2004 Ingersoll...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
UNUSED SWICT 72" BUCKET (A64280)
UNUSED SWICT 72"...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
JOHN DEERE 8335R TRACTOR (A64276)
JOHN DEERE 8335R...
24" Tooth Bucket (A64119)
24" Tooth Bucket...
