M7040SU underslung/downswept exhaust
/ M7040SU underslung/downswept exhaust #1
Farmer495
Nova Scotia, Canada
CaseIH / MF / Kubota
Does anyone have some up close photos of the underslung/down swept exhaust piping on an M7040SU?
Just curious, have to clear a low door and the vertical stack has to be removed, it's just a straight piece of pipe so I can put a shorter one on it, but wanted to see the factory set up.
/ M7040SU underslung/downswept exhaust #2
Delete. Attachment didn't work. Sorry.
OOPS, maybe it did! Look about 3/4 of the way down the parts diagrams.
/ M7040SU underslung/downswept exhaust #3
I'll try and remember to get a few pics of my m9540 tomorrow. Should be very similar if not exact same set up.
Looks like the entire muffler is different, the one I am looking at is one piece and points UP. I am guessing the factory version uses a totally different muffler.
/ M7040SU underslung/downswept exhaust #6
Like Derek, I'm not sure this will help you. I modified my vertical stack to the down mode. I used the parts from the upright stack to build what I needed to make it a horizontal or lower.
/ M7040SU underslung/downswept exhaust #7
Found these pics on Tractorhouse of a m7040d. Not sure if there is a difference between the "d" and "su" exhaust wise.
*For some reason the tbn app crashes if I try to add more than one pic at a time so I'll have to make a few separate posts.
/ M7040SU underslung/downswept exhaust #8
/ M7040SU underslung/downswept exhaust #9
/ M7040SU underslung/downswept exhaust #10
Thanks DT86 and ovrszd.
Might see if I can either do a couple of 90's to point down, or just get a straight pipe a few inches shorter than the factory one (it's about 5" too long and I don't want to cut it.......)
I don't want to modify the "normal" exhaust since I am fine with the upright pipe most of the time. It's only in the low door for the winter, but still has to come out for use.
/ M7040SU underslung/downswept exhaust #12
I don't recall my elbow being welded on. Memory says it was clamped. Anyway, removed it and used a piece of the vertical pipe to build the sweep I wanted.
I think once you convert it you will not go back to the vertical pipe. I am never smelling exhaust fumes. Only time I even know it's there is if the tractor is running and I spend more than a few seconds at the chain box which is just above where the pipe dumps.
Not sure how handy it would be to go to a muffler shop??? But I'm guessing for $20 they'd build you a sweep for low exhaust. Then you could clamp your elbow back on if you wanted vertical again.
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2007 International 4400 Day Cab Truck, VIN # 1HSMKAZN77H451431 (A61165)
INOP/NON-RUNNING...
2006 John Deere 1600 Turf Mower (A63116)
2006 John Deere...
