M59 Discussion Thread
/ M59 Discussion Thread #441
It may sound handy, but I think you're asking for trouble mounting a cutter on the front of a tractor. At the minimum you would need a screen radiator guard and a heavy lexan front guard with wings for the operator. Even then, I wouldn't suggest it. A lot of big shrapnel has bounced off surrounding objects and struck the side screens on my CTL. I wouldn't want to take a hit from one.
So
So I use my front remotes, though I've found out that it will kill them eventually - valve isn't mean't for constant flow. I wouldn't want to use it right at capacity, ie if it's rated for 16 go 12 or under.
Cutters for tractors are almost always better/cheaper on the 3 point hitch, but I don't know much about the one you are proposing, I'll have a look
so looked, and I think that's nuts honestly. Skidsteers have to do that, tractors don't. Get a heavy duty bush hog and do it on the back. I don't think the M59 will power that sufficiently either to get 6"
/ M59 Discussion Thread #444
I checked the "hydraulic hp" of the front remotes, and it came out to 24.5hp. Compare that to the 45 hp of the PTO and it makes quite a difference. Not to mention that mechanical losses are a lot less than hydraulic when in overloaded conditions.
/ M59 Discussion Thread #445
Sounds about right & is the root of the problem. Issue #2 is that the plumbing is probably not optimal. 3rd function plumbing is usually sized for grapples & intermitent duty cylinder. Fine for intermittent operation, but should be a size or 2 larger to minimize friction & minimize heating & parasitic losses for continuous use & optimal power transfer. Likely to loose a GPM or 2 & a few effective HP unless you optimize the plumbing
/ M59 Discussion Thread #446
No great reason to post the following, other than that it is a nice pic of the M59 on the road which I am sure some others will enjoy. Maybe useful as a reference point on hauling the M59. This was taken yesterday near Slumgullion pass, an 11,500' foot pass in SW Colorado, heading up for a summer of work on our ranch property.
Re front remotes, there is plenty of power for a hydraulic auger on the front remotes, and maybe a snow blower although I haven't tried that yet (but I could easily run a line from a rear remote if that worked out better). I wouldn't try to run a mower. I have a 6' PTO mower that I use on the back, with the backhoe removed. That, and the box blade, both benefit greatly from tip and tilt, which would be missing on the front.
/ M59 Discussion Thread #447
I love the mountains with a backdrop of snow especially when the roads are clear.
Quite a load you got there... does is pull OK at altitude?
/ M59 Discussion Thread #448
Yes - when towing heavy like this, it is more a matter of the grade being climbed than the altitude. The truck's diesel engine has a turbocharger (as does the M59), which helps to mitigate the effect of altitude. When pulling heavy up a grade, one will likely be in a lower gear, and the engine is turning over more which sucks in more air. The limit is more just the EGT i.e. work being done by the engine for the speed one is climbing. To see just the effect of altitude, a better test is when driving on a level road at altitude. Dropping a gear lower than usual is usually desirable when above 7000' or so. The most important truck features for towing in the mountains are a turbo-diesel, instrumentation including an EGT gauge at the minimum, an exhaust brake, and probably a tuning kit. And maybe a lighter trailer than my heavy dump trailer, although the combination of TLB plus dump trailer is very versatile when traveling.
Anyway, as this is an M59 thread, we probably shouldn't hijack it to talk about towing. Back when I got the M59 I was concerned about towing it in the mountains out West and there wasn't much information about other folk's experience doing so, so perhaps this will be a useful reference point for others (and an excuse to post the nice pic!).
/ M59 Discussion Thread #449
The earliest M59s are now close to ten years old, and probably some of them are coming up on time to check the valve lash. Has anyone done this? Anything special the rest of us should be looking for?
My own philosophy is too leave the valve lash alone if it measures within a few thousanths of nominal. But to do that, it has to be measured...which means rotating the engine by hand....and that always makes me a bit nervous.
rScotty.
/ M59 Discussion Thread #450
. But to do that, it has to be measured...which means rotating the engine by hand....and that always makes me a bit nervous. rScotty.
Just curious...
Why would this make you nervous?
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2015 Forest River Rockwood Freedom S/A Pop Up Camper Trailer (A59231)
2015 Forest River...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
207281 (A52708)
207281 (A52708)
