M4700
/ M4700 #1
design
Southern, NH
M5400
I just put a deposit on a used M4700.
The specifications that I could find conflicted with one another.
Would someone who has a brochure or who knows about/owns a machine please tell me the following:
Weight, (ROPS with 4WD) '97 model
Standard tire options and tract width, front and rear axle
What additonal options were available with the tractor.
Design.
/ M4700 #2
This data is found on Tractordata.com:
Model:M4700
Years produced:1995 - 1997
Power:
Engine:51 hp [38.0 kW]
PTO (rated):42 hp [31.3 kW]
Fuel:diesel
Cylinders:5
Bore/Stroke:
Displacement:167.5 ci [2.7 L]
Mechanical:
MFWD opt
3-Point Hitch:
Rear Hitch Category:I,II
Rear lift:4200 lbs [1905 kg]
Tires:
Ag front:6.50-16
Ag rear:14.9-28
Dimensions:
Weight:4000 lbs [1814 kg]
Wheelbase:78.7 inches [199 cm]
/ M4700
Thank you for the tractordata.com info. That data conflicts with over sources. Someone must have a brochure or a owners manual.
Design
/ M4700 #4
Froggy probably has the best reference for the correct specs.
:tiphat:
/ M4700 #5
Design
This data sheet from tractors usa is not an owners' manual- but it does seem to be a copy of a Kubota Brochure spec page for the M4700/M5400. It lists the M4700's normal R1 rubber as 9.5-22/14.9-28. The page implies the gearing was different in the two models, listing the M5400 with the same 9.5-22 front tires, but with 16.9-28 rears. The rears would have about 10" of circumference length difference between models. Seems like that would be a lot of scuffing to absorb without a gearing change too.
/ M4700
Dick,
Thanks for the information. The ad for this tractor that I put a deposit on has the engine listed as a 4 cylinder diesel. I wanted to be sure that all M4700's were the F2803 engine. This helps confirm that. This also confirms the weight of the tractor to be about 4,000 lbs not the 4,200 that I had seen in one other place.
As for the tire size. If I read the kubota book on tractor options, the m4700 has the same 16.9-28 rears with the same 9.5-22 fronts. This works out to be about a 5% change from the 14.9-28 tires. I agree; this seems like alot with out a gear change.
Design.
ps. I hope to get down to see the tractor this week.
2022 TRAC MV (A65643)
2015 MACK GRANITE (A65643)
2015 MACK GRANITE...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
LEEBOY SUPER 400 DOUBLE DRUM ROLLER (A65053)
LEEBOY SUPER 400...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
