m1735 engine bog using shredder
   / m1735 engine bog using shredder #1
chardage
2019 m1735
know this has been discussed. my story: 2019 M1735
- drained and bled main fuel filter
- cleaned outter air filter/ inner element ok
- added tractor oil (was pretty low)
- engine only bogs under bb7200X shredder. grass is not that high.
-disengage pto and all is good.
when it begins to bog i let up on fwd pedal and engine “catches up” with proper rpm.
the higher grass makes it bog, but not high or thick enough to bring engine to a virtual stop.
any ideas will be appreciated.
   / m1735 engine bog using shredder #2
Not a "shredder" it's a "rotary cutter"... Most often used vernacular is a "brush hog".... Cutter is probable to big for tractor (your tractor is rated at 36-40 HP) or you are trying to cut to much, to fast..... Cutter is actually recommended for tractors with 50 -150HP...
it’s a shredder and rated for tractor.
   / m1735 engine bog using shredder #4
If Wrangler is correct ( and I believe he is), you are basically FOS. Even if he is, have you sharpened the blades lately? Sharp blades cut way better than dull ones and use much less power as well and it appears you don't have all that much to begin with... I call both my bat wing and my flat back LP brush hogs, shredders as well but they are really not.
   / m1735 engine bog using shredder #5
I do know that my flat back 72" LP will work my tractor in heavy vegetation and I have over 90 pto horsepower and no hydro to rob power either.
You come on here, list your tractor model and brush hog model and tell Wrangler he is FOS. Not very becoming of a new member I'd say. Candidly, I had no idea what tractor you had until he clarified it. There are many diverse tractors with a bunch of model numbers and some overlap.
   / m1735 engine bog using shredder #6
That tractor is about 1/2 of the recommended MINIMUM PTO horsepower specified by the mower manufacturer.
To solve your bogging problem I recommend a slower speed, bigger tractor, or smaller brush cutter.
   / m1735 engine bog using shredder #7
Kind of surprised that little tractor can even lift that mower up. I know if I don't have the loader on the front of my M9 and have the 72 flat back LP on the 3 point and lift it up, I can actually feel the front end get light. it don't get light to the point where it lifts it but light enough where I can feel it in the steering and my tractors are about twice as big as his is.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
TANK MANIFOLD (A55745)
Push Mower (A59231)
Push Mower (A59231)
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Brent 1082 Auger Wagon (A59814)
Brent 1082 Auger...
